-1
STM32 microcontrollers have bootloader in system memory which is write-protected. This can be booted with right sequence, that I don't cover here.
ST provide more tools to upgrade firmware from bootloader that have DFU support. With DfuSeDemo.exe is possible to upgrade microcontroller even with enabled read protection. In shis case program ask if you want to remove read protection and than it downloads firmware to device.
I'm interested in automation of firmware updating, so I winder how to pass this requirement to command line.
DfuSeCommand.exe -c --al 0 -d --v --fn $dfuFlashFile
Use STM32CubeProgrammer instead of DfuSe that have also CLI to remove read-out protection and upload new firmware.
STM32 microcontroller reads boot pin at start-up to start bootloader. If you have USB it will start DFU. Remember that with removing read-out protection the microcontroller will restart - it will again test boot pin to come back to bootloader.
Figure 41 on page 47/93 of User manual UM2237 STM32CubeProgrammer software description shows CLI commands.
Removing read protection
To remove read-out protection use (section 3.2.15 in UM2237)
STM32_Programmer_CLI -c port=usb1 -rdu
here keep boot pin on vcc to come back into bootloader (get back DFU). uC is now unprotected and erased!
-rdu option Remove memory's Read Protection by shifting the RDP level from level 1 to level 0.
Writing/downloading new firmware and verification
STM32_Programmer_CLI -c port=usb1 -w "firmware.elf" –verify
or .hex or whatever you have, STM32_Programmer will figure it out.
Setting read protection
You can also back protect uC by setting RDU in optionByte (section 3.2.17 in UM2237)
test option bytes ability with:
STM32_Programmer_CLI -c port=usb1 -ob displ
than use option byte name for setting protection level as you need
STM32_Programmer_CLI -c port=usb1 -ob rdp=0xBB
Carefull!! Level 2 read protection will lock your stm32 uC! Chech documentation for your uC, usualy 0xCC is level 2 protection, 0xBB is level 1 protection and 0xAA and others is level 0 protection (unrotected).
  • \$\begingroup\$ Use ./STM32_Programmer.sh on linux or /STM32_Programmer_CLI.exe on windows \$\endgroup\$
    – mitjajez
    Jan 2, 2021 at 16:53
