Transfer Function
Below is the circuit I built, yet the solution has the resistor as a load resistor instead of as a current limiting resistor. I am wondering if this circuit will output this transfer function.
circuit
You're almost there... The diode network you came up with makes sense.
However, your circuit will clamp the output voltage at +0.7 and -4.7V instead of presenting a transfer function with slope=1 as requested.
Consider having the diode network in series between Vi and Vo instead. It's a good idea to have a shunt resistor on the output side to make sure Vo goes to zero between -4.7V and +0.7V.
| improve this answer | |
Just in case it helps (and because you already have selected an answer, so no harm no foul), something like this is what was suggested I think:
A Spice simulation shows:
