I have a 1V pk to pk analogue signal and need to shift and amplify the voltage to 0.5-2V.The supply into the amplifier is ±10V. The frequency of the signal is 500 - 1000Hz.
What sort of circuit should I be looking at? Not wanting anyone to send circuits, just need some pointers in the right direction.
    \$\begingroup\$ Opamps for everyone. Noninverting amplifier \$\endgroup\$ – DKNguyen Oct 18 '19 at 14:42
  • \$\begingroup\$ Might be easier to do the bias with an inverting amp except it will invert \$\endgroup\$ – DKNguyen Oct 18 '19 at 14:49
  • \$\begingroup\$ Are you able to use +/- power supplies, or are you limited to + power. \$\endgroup\$ – Scott Seidman Oct 18 '19 at 14:59
  • \$\begingroup\$ what source impdance? is source DC_blocked? \$\endgroup\$ – analogsystemsrf Oct 18 '19 at 15:08
    \$\begingroup\$ Digital or analog signal? What frequencies it has? \$\endgroup\$ – Justme Oct 18 '19 at 15:11
