I am using the MAX3665 in a design. The amplifier has an IR Photodiode at the input and is failing to detect any signals. My signal generator outputs a maximum of MHz square waves and MHz sine waves.
How do I know what the operating frequency of the MAX3665 is?
  • \$\begingroup\$ It has a DC cancellation loop. \$\endgroup\$ – DKNguyen Oct 18 at 15:55
  • \$\begingroup\$ No link nor mention of the datasheet? \$\endgroup\$ – JYelton Oct 18 at 17:49
The small signal response starts to drop significantly after 100kHz, flat from 500kHz to 700MHz. You should be able to see signals of a 100MHz. It could be something else. I would test the transmitter with a detector that you know that works to make sure that it's not the transmitter.
