I have searched the statement; MOS worst-case gate capacitance in various forms but no avail.
Keep in mind I'm a student. The course I am taking has no reference material. With note slides with pictures and formulas.
The only "formulas" that are provided for gate capacitance are:
There is no text on what does a worst case gate capacitance per unit area means. Yet there is a homework question on it. There was no mention of it in class.
What does it mean? And how do you judge it is worst-case?
  • \$\begingroup\$ A large gate capacitance will cause a FET to switch more slowly and increase switching loss. I would assume the "worst case" gate capacitance is the largest value the transistor can have. \$\endgroup\$ Oct 18, 2019 at 21:03
    \$\begingroup\$ "The course I am taking has no reference material." You should seriously consider better quality courses! \$\endgroup\$
    – JYelton
    Oct 18, 2019 at 21:05
  • \$\begingroup\$ Also need to show the transistor model to see where Cj and Ceq is \$\endgroup\$
    – Voltage Spike
    Oct 18, 2019 at 21:17
  • \$\begingroup\$ In general, "worst case" means "the worst it can get" -- which means you need to know what worse is. In the case of gate capacitance, that's bigger -- circuit designers would love to get their hands on FETs with zero-capacitance gates. \$\endgroup\$
    – TimWescott
    Oct 18, 2019 at 21:28
  • \$\begingroup\$ i think of a data sheet's min and max and typical specs for a mosfet; worst case would be max. \$\endgroup\$
    – dandavis
    Oct 18, 2019 at 21:34
The worst case gate capacitance is simply the max. gate capacitance specified in its datasheet. The highest value is considered the worst because higher means slower to switch on/off from the same drive circuit.
This maximum value will allow for variations in material properties and temperature.
