I have coded a simple signed 4 bit adder. It doesn't have any carry in or carry out so it easily overflows. Below you can see my code.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity four_bit_adder_simple is
        port(
                A, B : in std_logic_vector(3 downto 0);
                Sum : out std_logic_vector(3 downto 0));
end four_bit_adder_simple;
architecture signed_impl of four_bit_adder_simple is
begin
        sum <= std_logic_vector(signed(A) + signed(B));
end signed_impl;
Port mapping:
library ieee;
entity four_bit_adder_tester is
    port(
            SW : in std_logic_vector(7 downto 0);
            LEDR : out std_logic_vector(3 downto 0));
end four_bit_adder_tester;
architecture tester_impl of four_bit_adder_tester is
begin
i1: entity work.four_bit_adder_simple(signed_impl)
    port map(
    A => SW(3 downto 0),
    B => SW(7 downto 4),
    Sum => LEDR(3 downto 0)
end architecture;
How can I add a carry-in and a carry-out by using the resize function to change the bit size of the vectors before adding them together?
  • \$\begingroup\$ why do you have a requirement to use the resize function? \$\endgroup\$ Oct 18, 2019 at 22:02
  • \$\begingroup\$ @BlairFonville To prevent overflowing. \$\endgroup\$
    – user164324
    Oct 18, 2019 at 22:11
  • \$\begingroup\$ you prevent overflow by adding only 3 bit numbers \$\endgroup\$
    – jsotola
    Oct 18, 2019 at 22:52
  • \$\begingroup\$ If your inputs and outputs are signed numbers, you can give them type signed instead of std_logic_vector. You then won't need any type conversion. \$\endgroup\$
    – scary_jeff
    Oct 23, 2019 at 9:09
You don't need the resize function. Just create an internal signal of the correct length, and concatenate 0's to your inputs. Such as:
library ieee;
use ieee.std_logic_unsigned.all;
    Port ( a    : in  std_logic_vector(3 downto 0);
           b    : in  std_logic_vector(3 downto 0);
           cin  : in  std_logic;
           sum  : out std_logic_vector (3 downto 0);
           cout : out std_logic );
architecture Behavioral of four_bit_adder_simple is
    signal total : std_logic_vector(4 downto 0);
begin
    total <= ('0'&a) + ('0'&b) + cin;
    sum   <= total(3 downto 0);
    cout  <= total(4);
end Behavioral;
edit
In hindsight, using the non-standard std_logic_unsigned is not the best approach (When to use VHDL library std_logic_unsigned and numeric_std?).
See my answer here instead.
  • \$\begingroup\$ Isn't there a way to do this with the resize function? My assignment tells me to do so... \$\endgroup\$
    – user164324
    Oct 18, 2019 at 22:30
  • \$\begingroup\$ @user164324 I asked why you needed resize... you said "to prevent overflowing". But yes, you can replace the sum above with a sum of signed(a) and signed(b), each resized to 5. Then cast that sum to std_logic_vector, and add cin. And put "use ieee.numeric_std.all" back. \$\endgroup\$ Oct 18, 2019 at 23:08
