I'm trying to make a 4 bit adder with carry in & out, but I am having trouble converting Cin (Carry-in) to the type std_logic_vector when summing Sum and Cin together below in the architecture. Do you have any idea how i can make these types fit so that I can perform arithmetic on them together?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity four_bit_adder_simple is
        port(
                A, B : in std_logic_vector(3 downto 0);
                Cin : in std_logic;
                Sum : out std_logic_vector(3 downto 0);
                Cout : out std_logic);
end four_bit_adder_simple;
architecture unsigned_impl of four_bit_adder_simple is
    signal total : std_logic_vector(4 downto 0);
begin
        Sum <= std_logic_vector(resize(unsigned(A),5) + resize(unsigned(B),5));
        total <= Sum + Cin;
        Cout <= total(4);
end unsigned_impl;
EDIT: It was an error that I made Cout a 2 bit std_logic_vector. It should just have been a simple std_logic.
    \$\begingroup\$ Cout is 2 bits wide, which is odd... You are possibly missitg the fact that an array aggregate with one member can't use positional association. So use named association. (0 => Cin) is a 1 bit SLV. \$\endgroup\$ – Brian Drummond Oct 19 '19 at 18:45
  • \$\begingroup\$ @BrianDrummond You need to add Cin, not concatenate it. So the total line is wrong. \$\endgroup\$ – user110971 Oct 19 '19 at 18:53
  • \$\begingroup\$ As @BrianDrummond says, Cout looks like it should be corrected to a std_logic output. \$\endgroup\$ – TonyM Oct 19 '19 at 18:54
  • \$\begingroup\$ If Cout should be an SLV, it should be a 1 bit SLV, e.g. (0 downto 0). And I was merely converting Cin to a SLV. Who mentioned concatenation? \$\endgroup\$ – Brian Drummond Oct 19 '19 at 18:58
    \$\begingroup\$ Re: your edit. You still have an error. Your output Sum doesn't take Cin into account. \$\endgroup\$ – Blair Fonville Oct 19 '19 at 21:06
You need to cast cin to an unsigned, then add it in.
library ieee;
    Port ( a    : in  std_logic_vector(3 downto 0);
           b    : in  std_logic_vector(3 downto 0);
           cin  : in  std_logic;
           sum  : out std_logic_vector (3 downto 0);
           cout : out std_logic );
architecture Behavioral of four_bit_adder_simple is
begin
    total <= std_logic_vector(resize(unsigned(a),5) + resize(unsigned(b),5) + unsigned'('0'&cin));
    sum   <= total(3 downto 0);
    cout  <= total(4);
end Behavioral;
You'll end up with this: adder
Note that resize returns an unsigned here.
| improve this answer | |
  • \$\begingroup\$ Thanks, it seems to work now! \$\endgroup\$ – user234430 Oct 19 '19 at 21:31
  • \$\begingroup\$ To simplify the code above, most type conversion/casting can be avoided by simply giving signals and ports the appropriate numeric type in the first place. \$\endgroup\$ – scary_jeff Oct 23 '19 at 8:11
The following is a simplification of your design that meets all the requirements and compiles in VHDL-93 onwards. It uses std_logic_unsigned rather than numeric_std. (Forgive the style changes, automatic when I typed and tested it.)
library ieee;
use ieee.std_logic_unsigned.all;
entity FOUR_BIT_ADDER_SIMPLE is
  port(
    A                             : in  std_logic_vector( 3 downto  0);
    B                             : in  std_logic_vector( 3 downto  0);
    C_IN                          : in  std_logic;
    SUM                           : out std_logic_vector( 3 downto  0);
    C_OUT                         : out std_logic
end FOUR_BIT_ADDER_SIMPLE;
architecture RTL of FOUR_BIT_ADDER_SIMPLE is
  signal total                    : std_logic_vector( 4 downto  0);
begin
  total  <=  ('0' & A) + ('0' & B) + ("0000" & C_IN);
  SUM    <=  total( 3 downto  0);
  C_OUT  <=  total( 4);
end architecture RTL;
The 5-bit addition is done in one line by first padding each element with leading zeroes.
    \$\begingroup\$ You cannot add std_logic_vectors like that. You need to cast them to a numeric type first. \$\endgroup\$ – user110971 Oct 19 '19 at 18:56
    \$\begingroup\$ It doesn’t work. It is only supported in VHDL-2008, but you must use ieee.numeric_std_unsigned. \$\endgroup\$ – user110971 Oct 19 '19 at 19:08
  • \$\begingroup\$ @user110971 this does work but uses std_logic_unsigned, which is a non-standard package. You are correct that in VHDL-2008 the same functionality has been included in the standard library numeric_std_unsigned. \$\endgroup\$ – ks0ze Oct 19 '19 at 20:51
    \$\begingroup\$ @ks0ze My above comment was a reply to a now deleted comment, so it seems confusing. Indeed the edited answer now works, but uses non-standard libraries, which is just bad practice. If you want to avoid excessive casting, you should just use Verilog. VHDL is a strongly typed language, which can be really annoying at times. In fact, I do prefer Verilog. See the original answer for the full context of my comment. \$\endgroup\$ – user110971 Oct 19 '19 at 21:30
    \$\begingroup\$ @TonyM Well I know about a case wherein the change of an FPGA vendor almost resulted in someone’s death due to the use of non-standard libraries. Avoid good practice at your own peril. \$\endgroup\$ – user110971 Oct 19 '19 at 21:34
