This is a common drain MOSFET amplifier:
This is its small signal model at low frequency:
I am at a loss as to how to find Vout/Vin. Vin, in this case, is just Vg not Vgs since the source node is not connected to ground.
My analysis:
Since all of the current source's current is going thru r0 from Vout to GND,
$$\frac{V_{out}}{r_0}=V_{gs}*g_m$$ or $$\frac{V_{out}}{r_0}=(V_{in}-V_{out})*g_m$$. After some algebraic manipulation, you get $$\frac{V_{out}}{V_{in}}=\frac{r_0*g_m}{1+r_0*g_m}$$.
I know $$r_o*g_m=(\frac{\delta I_d}{\delta V_{ds}})^{-1}*\frac{\delta I_d}{\delta V_{gs}}=\frac{\delta V_{ds}}{\delta V_{gs}}$$.
I don't know what to do after this. My professor's solution says Vout/Vin=1. How?
    \$\begingroup\$ The circuit as drawn has zero gain. That is, the output is completely independent of the input. Are you sure you drew it right? \$\endgroup\$ – Hearth Oct 20 '19 at 0:19
Vgs = 5V so RsOn is low and you have a SOURCE follower ( or common drain ) with some unknown load resistance say 100x RdsOn which is missing between Source and Vss.
So it's a drain follower, like a unity gain emitter follower with a gain=<1 depending on load regulation, Roin and a DC bias above Vgs(th).
But a rather sloppy logic diagram with errors... tisk.
Other _ - - Here is how I would make a 1GHz buffer Av =1 almost unity
I added Ciss and Rg to the model with very low RdsON Vt=1V and due to load regulation from Ron and insufficient Vgs bias from Vss the Vout DC is a bit more than -1V.
Go back and review your common drain notes for details.
