I'm currently using a PLC to control an induction heating coil.
I'm using a chinese induction driver that allows 4-20mA PID input. This device runs off standard australian 230v AC 50hz.
I've successfully operated the device using a standalone PID controller that also runs off mains power.
My PLC runs of 24v DC and has it's own din rail mounted power supply.
The output 4-20mA signal is referenced to the chassis of the PLC.
When I connect my PLC PID output to the chinese induction driver PID input, the driver short circuits catastrophically.
I believe this is due to the ground reference of the driver unit and my PLC being different. I confirmed this by measuring the potential difference between the two PID signal negatives and found that there was a 109V DC difference, which explains why the driver overloaded.
My question is, how can I reference the ground of my PLC to the induction driver unit?
I've gone through the circuitry of the induction driver and believe it does not have any features for sharing a ground reference. It receives it's power by L and N wires from a mains outlet. The control board of the induction driver has no grounds to it's chassis enclosure as such, I believe connecting the two chassis would provide no solution.
The standalone PID controller that worked perfectly also operates off mains power (L and N wires with no earth) and provides a 4-20mA signal that the induction driver seems to agree with.
Any information would be greatly appreciated, thank you.
Hard to tell without datasheets for the relevant products, but it sounds like the driver lacks isolation between the 4-20mA input and the mains. If so, this is a rather sub-standard design.
You can use it if you add a 4~20mA:4~20mA isolator between the PLC and the driver. Make sure the isolator is rated to continuously withstand mains voltage.
