I have written a bootloader for my board, but it generates a hard fault when it jumps to the application code.
My error is like this question:
Bootloader jump to main application problem using STM32 with Keil Uvision
- microcontroller: stm32f103zet
- software: keil
- BOOT pins: BOOT1 and BOOT2 are 0 (FLASH boot mode)
- FLASH_WRITE_ADDRESS: 0x8030000
I did this steps: in application code:
- I changed ROM address to 0x8030000.
- I changed VECT_TAB_OFFSET to 0x30000
- I used of fromelf for creating .bin file
then I wrote a simple code (blinky)
in bootloader code: i receive .bin file with USART and then i write it to address 0x8030000 of FLASH and The following code:
USART_DeInit(USART1);
RCC_DeInit();
__set_CONTROL(ENABLE_PRIVILEGE_MODE);
NVIC->ICER[ 0 ] = 0xFFFFFFFF ;
NVIC->ICER[ 1 ] = 0xFFFFFFFF ;
NVIC->ICER[ 2 ] = 0xFFFFFFFF ;
NVIC->ICPR[ 0 ] = 0xFFFFFFFF ;
NVIC->ICPR[ 1 ] = 0xFFFFFFFF ;
NVIC->ICPR[ 2 ] = 0xFFFFFFFF ;
SysTick->CTRL = 0 ;
SCB->ICSR |= SCB_ICSR_PENDSTCLR_Msk ;
SCB->SHCSR &= ~( SCB_SHCSR_USGFAULTENA_Msk |
SCB_SHCSR_BUSFAULTENA_Msk |
SCB_SHCSR_MEMFAULTENA_Msk );
__disable_irq();
if( CONTROL_SPSEL_Msk & __get_CONTROL( ) )
{ /* MSP is not active */
__set_MSP( __get_PSP( ) ) ;
__set_CONTROL( __get_CONTROL( ) & ~CONTROL_SPSEL_Msk ) ;
JumpAddress=(FLASH_WRITE_ADDRESS+4);
JumpToApplication =(void(*)(void))(*((uint32_t*)JumpAddress));
__set_MSP(*(__IO uint32_t*)FLASH_WRITE_ADDRESS);
JumpToApplication();
But it goes to hardfault. So now I use this part of the code:
/* Jump to user application */
JumpAddress = *(volatile uint32_t*)(FLASH_WRITE_ADDRESS+4);
JumpToApplication = (pFunction) JumpAddress;
__set_MSP((*(volatile uint32_t*) FLASH_WRITE_ADDRESS));
now_pointer=__get_MSP();
but it is the same as before. What is problem?
This is one second before jump to application code:
And this is result of jump to application code:
okey.now,i find and solve problem:
i put my writing in FLASH mistake picture:
