All the two/three process block modeling style(the recommended style) examples for FSM have logic for nextstate that is a function of current state and inputs. The outputs in these examples also take specific values depending on current state and optionally inputs.
Ex :
always_ff@(posedge clk) begin
if(rst) currentState<=IDLE;
else currentState<=nextState;
end
always_comb begin
nextState = 'x;
case(currentState)
IDLE : if(in1) nextState = CALC1;
else nextState = IDLE;
CALC1 : if(in1) nextState = CALC2;
else if(in2) nextState = IDLE;
else nextState = CALC1;
endcase
end
always_comb begin
out1 = '0;
out2 = '0;
case(currentState)
CALC1 : out1 = 1'b1;
CALC2 : out2 = 1'b1;
endcase
end
Consider an example for an FSM for a memory BIST. I want my FSM to be in state1 while my address is less than 1000, change to state2 when it reaches the value of 1000. I want the address to keep incrementing from 0 to 1000 while in state1 and start decrementing when in state2. Furthermore I want my FSM to be in state0 for 500 cycles just after reset.
always_comb begin
nextState = 'x;
case(currentState)
state0 : if(resetCount<500) nextState = state1;
else nextState = state0;
state1 : if(addr<1000) nextState = state2;
else nextState = state1;
state2 : if(addr>0) nextState = state3;
else nextState = state2;
endcase
end
case(currentState)
state0 : addr<='0;
state1 : addr<=add+'d1;
state2 : addr<=add-'d1;
endcase
end
if(currentState=='0) resetCount<=restCount+'d1;
else resetCount<='0;
end
The next state and output calculation is not straight forward. If I keep adding signals like data/control signals, these dependencies will increase.
For a case such as this, is it still recommended that we follow 2/3 process block FSM and remove all the extraneous logic(Ex : the reset counter) from the module where FSM is coded? I can move the reset counter outside of the FSM module and have a signal indicate to the FSM when counter reaches 500, and generate a signal from FSM that indicates to the counter outside the FSM to count or not depending on state.
But isn't it extra effort just to keep it in 2 processes?
