I got into FPGA design last year for a project, and had some success with a Xilinx Spartan 6 dev board using ISE. I could do everything with this low cost board and ISE 14, which is free. I needed an embedded processor and used the excellent PicoBlaze - again thanks to great documentation this all worked very well and the project is currently in daily use.
Like many successful projects I can see things growing in future. I still have a fair amount of capacity on the FPGA, but the issue with PicoBlaze really is lack of a C compiler. I would like to find another processor that is very low cost or free, but for which I can build with gcc or whatever.
I had a look around opencores and some interesting things there - but a bit hard to tell what is actively maintained and has a user base. Can anyone recommend free/low cost embedded processor(s) that work well and are reasonably well documented?
    \$\begingroup\$ I think ARM recently made some soft-cores free. \$\endgroup\$
    – DKNguyen
    Oct 23, 2019 at 21:34
  • \$\begingroup\$ @VoltageSpike not quite true: opencores.org/projects?expanded=Processor \$\endgroup\$
    – user16222
    Oct 23, 2019 at 21:53
  • \$\begingroup\$ it looks like a comment is missing? VoltageSpike? \$\endgroup\$
    – danmcb
    Oct 23, 2019 at 22:30
  • \$\begingroup\$ I remember we were willing to pay $1m for the HC07 core until funding pulled the plug after 7 years. \$\endgroup\$ Oct 23, 2019 at 23:09
    \$\begingroup\$ or you could just use the microblaze and the gnu toolchain... \$\endgroup\$
    – old_timer
    Oct 24, 2019 at 2:21
4 Answers 4
Besides the likes of RiscV, there is OpenRISC ( https://openrisc.io/ )
a free and open RISC instruction set architecture with DSP features
a set of free, open source implementations of the architecture
a complete set of free, open source software development tools, libraries, operating systems and applications
a variety of system-on-chip and system simulators
The or1200 implementation is done is verilog and is released under the LGPL license
https://github.com/openrisc/or1200
mor1kx is written in verilog and released under the OHLD license
https://github.com/openrisc/mor1kx
I have heard a lot of good stuff about vexriscv. In general, there is a lot of work around the riscv instruction set, in terms of compilers, soft processors, and all sorts of ASIC implementations.
The Hennessy & Patterson textbook now covers the RISCV architecture. Tons of academic papers on a wide range of RISCV implementations (including FPGA). Also there is a RISCV consortium consisting of multiple very large companies. So that open source architecture is well documented and likely to be well supported by software for a very long time.
I have been using the Instant Soc RISC-V in a couple of projects now. It really works great. It build an optimized RISC-V core and all around that based on your C++ code. It uses gcc and a compiler that builds the HDL.
