I doubt if the way I am converting the logical level is correct and if it is the best way to do this.
The PWM_1 signal comes from a STM32F4 microcontroller. When PWM_1 = logic level 1 I have 3.3V. When PWM_1 = logic level 0 I have 0V.
I need PWM_1's 3.3V to be converted to 0V in OUT_1 and PWM_1's 0V to be 5V on OUT_1 output.
As the SN74HC04D logic port is being powered with 5V it only recognizes logic level 1 when it has 3.5V in the input (according to the datasheet). So I need to do the logical conversion from 3.3V to 5V.
I would not want to use an integrated circuit for this, so I thought of that circuit with Mosfet-n.
I wonder if this is the best way to convert logical level without using integrated circuit.
    \$\begingroup\$ What is the frequency of the PWM signal? \$\endgroup\$ Oct 29, 2019 at 13:00
  • \$\begingroup\$ PWM frequency is 20KHz. \$\endgroup\$ Oct 29, 2019 at 13:01
  • \$\begingroup\$ I'd use an SN74LVC1T45 level translator. Not sure why you need to do without IC's, it will certainly take more board space to do this with discrete components, and cost more. \$\endgroup\$ Oct 29, 2019 at 13:03
Just replace the 74HC04 with 74HCT04 and you don't need any other components. It will accept 3.3V levels and output 5V levels.
  • \$\begingroup\$ Excellent answer. Analyzing the 74HCT04 datasheet, I noticed that it recognizes logic level 1 with values above 2V. Thank you very much. \$\endgroup\$ Oct 29, 2019 at 13:19
  • \$\begingroup\$ You should mention that this circuit also inverts the PWM signal so the duty factor is changed. \$\endgroup\$ Oct 29, 2019 at 14:17
  • \$\begingroup\$ @ElliotAlderson That's actually in the OP's requirements. \$\endgroup\$ Oct 29, 2019 at 14:56
  • \$\begingroup\$ OK, I see, you are replacing the inverter as well, not just performing level conversion. You could improve your answer with a bit of text to explain it. \$\endgroup\$ Oct 29, 2019 at 15:06
