Conceptual question: When you have a super complicated circuit, does it matter which node you start at when finding equivalent resistance? How about capacitance?
\$\begingroup\$ For hand calculation via nodal analysis all the selected nodes must be considered, so it makes no difference in which order they're done. What exactly does how about capacitance? mean? \$\endgroup\$– ChuNov 2, 2019 at 20:02
1 Answer
Two ways to answer this question:
If the circuit is really complicated, you will be using a linear algebra or matrix solution method to solve it, not combining elements in any particular order.
If changing the order of operations in your method of finding the equivalent resistance creates different results, then one or the other of your methods (or both) is faulty.
