We have a 50 pair cable running about 1.5-2 KM with some services running on different pairs. One pair has recently become intermittent and is losing connection for 1-2 seconds at random. It might happen a few times an hour, so I jumped the service onto another pair. There is a modem connected to the pair for communication between two sites.
When resistance tested with a multi meter with a loop in one end it was reading 330 Ohms. When using an oscar meter it was reading -2.4db which is the same readings for other pairs.
I would like to use an Arduino to monitor the line resistance for a few days and see if there are any spikes or breaks in the line. I was going to use an analog input as a multimeter by using a known resistor and the looped pair as the other resistor. As seen here.
Does anybody think this will not work?
How else could I go about this?
What you plan should work. I'd log the data to a PC with a timestamp. You can then analyse the measurements later to see if the disturbances occur at a particular time of day.
