Suppose you have to amplify a signal with a gain of 2 .
The signal is referenced to ground, which means V1 is zero.
Is there any reason why one would use this circuit below instead of a normal non-inverting amplifier.
Picture obtained from https://www.electronicshub.org/differential-amplifier/
So in that case what is the difference between this circuit and the "normal" non-inverting amplifier were R2=zero and R4= removed. The only difference I see, is that with the differential amplifier you are able to achieve a gain less than 1. Are there any more reasons?accuracy?etc
