I am looking for a wheel that you can push into as a button as well as scroll indefinitely in either direction.
Here's the exact part I am talking about. I'm not sure exactly what it is called.
Image of scrolling wheel with click
The ultimate goal is to be able to tell a direction of the scroll and how fast the scroll is in order to cycle through options and to be able to press into the wheel to confirm a selection.
I've found so far something called a "Rotary B Click" which indefinitely scrolls in either direction and has a button but the button action is in the wrong direction (towards the board instead of towards the wheel axis). It also seems that it is a rather large component, I am looking for something smaller.
I also found this component(potentiometer) which only rotates once and doesn't click but visually looks close to the component I'm looking for.
  • \$\begingroup\$ Welcome to EE.SE but please note that direct shopping questions will result in fairly prompt closure of your question as per site rules. Editing your question to make it clear that you are looking for the correct search terms, etc., is fine. \$\endgroup\$ – Transistor Nov 4 '19 at 18:37
Try searching for "thumbwheel encoder". A number of hits look promising, such as this one (not in stock so you will probably have to keep looking for yourself).
Electrically it's just a normal mechanical quadrature encoder with a mechanical push switch, so a standard firmware/hardware approach would work, perhaps tweaked for the amount of bounce and number of detents or steps.
