I've got a voltage regulator in a circuit, along with its recommended protection diode:
Schematic
On my PCB, I'm using large copper pours for the Vin (Pin 1) and Vout (Pin 3) connections, as these are used frequently in other high current components in the rest of the circuit.
My top copper pours are split exactly in half, with the Vin pour to the left of the chip (red) and the Vout pour to the right of the chip (blue). I have a seamless Ground plane on the bottom layer.
Can I simply place the protection diode near the chip - with its terminals connected to the Vin and Vout planes as below? Or should I be routing traces specifically to isolate the diode/chip from the pours (forcing the diode to be the "gateway" to the pours for the chip?)
PCB
    \$\begingroup\$ This is a low frequency issue, it should not matter either way. \$\endgroup\$
    – MadHatter
    Nov 5, 2019 at 15:54
  • \$\begingroup\$ In a lot of cases you don't need the diode at all. \$\endgroup\$ Nov 5, 2019 at 20:04
That diode is merely to protect the regulator chip in the event that Vin ever becomes lower than Vout. This is usually at power down and depends on the loads. It's not high frequency, so layout is not that important. What you have will work just fine.
If you want to visualize what is happening, a way I would recommend would be to get a pcb trace calculator and find what the actual values are, then 'draw' the parasitic values into your schematic and see what difference it makes.
A 15mil trace about 100mil long has a resistance of ~3mΩ, with a plane connection, the resistance is lowered further because there is more copper and less resistance. 3mΩ in this application is negligible. If you doubled the distance, that would be 6mΩ, nothing to worry about.
With a plane connection the parasitic resistance is also reduced between the diode and other areas of the PCB, I would think that in almost every case a plane would be better for less resistance to the diode.
