I am trying to create a register file in Verilog. To do this, I am instantiating multiple instances of a register module I designed in a generate statement. Each module uses a different input and output signal, so I declared an array of buses and indexed them with the genvar in the loop. When trying to synthesize the module, I receive an error informing me of untrimmed latches.
I am using Xilinx ISE
This is the module code:
module RegisterFile(
input [3:0] RsAddr,
input [2:0] RsShortAddr,
input [3:0] RtAddr,
input [3:0] RdAddr,
input [2:0] RdShortAddr,
input [15:0] WriteAddr,
input [15:0] WriteData,
input WriteEnable,
input Reset,
input Clock,
output reg [15:0] Rs,
output reg [15:0] RsShort,
output reg [15:0] Rt,
output reg [15:0] Rd,
output reg [15:0] RdShort
localparam zero = 16'd0, sp = 16'd1, t0 = 16'd1, t1 = 16'd2, t2 = 16'd3,
ra = 16'd5, s0 = 16'd6, s1 = 16'd7, s2 = 16'd8, rv0 = 16'd9, rv1 = 16'd10,
arg0 = 16'd11, arg1 = 16'd12, at = 16'd13, k0 = 16'd14, k1 = 16'd15;
reg [15:0] RegInputMatrix [15:0];
wire [15:0] RegOutputMatrix [15:0];
generate
genvar i;
for (i = 0; i < 15; i = i + 1) begin : RegisterMatrix
Register all_Register-5 5(
.DIN(RegInputMatrix[i]),
.WR_EN(WriteEnable & ~Reset),
.Reset(Reset),
.CLK(Clock),
.DOUT(RegOutputMatrix[i])
end
endgenerate
// Write to a register
always @(*) begin
if (Reset)
RegInputMatrix[WriteAddr] <= 16'b0;
else
RegInputMatrix[WriteAddr] <= WriteData;
end
// Decode output logic
always @(posedge Clock or posedge Reset) begin
if (Reset) begin
Rs <= 0;
RsShort <= 0;
Rt <= 0;
Rd <= 0;
RdShort <= 0;
end
else begin
Rs <= RegOutputMatrix[RsAddr];
RsShort <= RegOutputMatrix[RsShortAddr];
Rt <= RegOutputMatrix[RtAddr];
Rd <= RegOutputMatrix[RdAddr];
RdShort <= RegOutputMatrix[RdShortAddr];
end
end
endmodule
I get the following warnings
WARNING:Xst:647 - Input <WriteAddr<15:4>> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:653 - Signal <RegOutputMatrix<15>> is used but never assigned. This sourceless signal will be automatically connected to value 0000000000000000.
WARNING:Xst:646 - Signal <RegInputMatrix<15>> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_0>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_1>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_2>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_3>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_4>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_5>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_6>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_7>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_8>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_9>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_10>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_11>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_12>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_13>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 16-bit latch for signal <RegInputMatrix_14>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
As mentioned above, I believe the Register module is working, but I can provide the hardware description for it if necessary.
RegInputMatrix
in youralways
statement, so it needs latches to keep the previous values. \$\endgroup\$
