I am looking at implementing a MOSFET Bridge Rectifier circuit. I am trying understand why there is a difference in the basic application circuit and layout from the app note. The layout image below has resistors while the basic application circuit does not.
The app note shows a basic application circuit here:
But then shows a layout with resistors 8 total as seen here:
Does anyone know what the purpose of those resistors could be?
    \$\begingroup\$ are you sure that they are resistors? \$\endgroup\$
    – jsotola
    Commented Nov 7, 2019 at 15:20
    \$\begingroup\$ If the IC is orientated the same way as the diagram on page 4 (pin 1 to bottom right) then those resistors are on the gates of the MOSFETs, so they could just simply be pull-ups or pull-downs on the gates \$\endgroup\$
    – MCG
    Commented Nov 7, 2019 at 15:40
They look like zero ohm jumpers to me. They'd be used change the setup of the circuit on those evaluation boards.
