So I had a sealed lead acid battery which have a characteristics of 4Ah and 6v and 20h.
First if all when I searched about discharge rate of this kind of battery I found this "The sealed lead-acid battery is rated at a 5-hour (0.2) and 20-hour (0.05C) discharge".
I incidentally had a lipo battery of 7.2v 1000mAh rated at 35C which after a bit of research , it turned out that this number is the maximum safe current it can deliver so 35 * 1000 which is 35000mA or 35A.
So is this the same for lead acid battery? So for my battery I get 0.05*4000 200mA only or I mixed two different meanings together ?
