I'm looking for an oddball stacked USB connector to repair a piece of equipment. I can't use the standard form factor, because it won't fit into the enclosure properly.
I've gone through mouser and newark and several other websites and can't seem to find anything that matches. A verbal description: Imagine a standard 2-port stacked PCB mount USB-A connector. Now imagine that the 8 pins are inset vertically about 5mm, such that the connector is mounted into a cutout in the pcb, and dangles below the pcb a smidge.
A sloppy side-view picture:
