I own a torch/flashlight which requires a 26650 2000mAh rechargeable battery.
I'd like to power it with a power adapter, but all I can find here is 3V or 4.5V so it's either too low or too high.
EDIT: 26650 rechargeable battery is 3,6V - 3,7V
  • \$\begingroup\$ You must specify current with voltage \$\endgroup\$ – Tony Stewart EE75 Nov 8 '19 at 20:27
There is some options to choose from:
Option 1 - Lower power
Go with the 3V power supply and the torch will like still work (maybe not at full brightness)
Option 2 - Regulate it down
Get a power supply with a higer voltage and regulate it using either a linear voltage regulator or a DC-DC buck regulator.
Option 3 - Drop voltage with diode
Get the 4.5V power supply and place a diode in series, which will drop about 0.7V making it 3.8V which should be fine for the torch.
