What if I don't have the serial cable connected to the serial port, still I receive serial packets from CPU? (lets say console output is enabled in Software) Will those packets got terminated (discarded) at the serial port connector end at board?
  • \$\begingroup\$ It's unlikely that these are "packets" except in the sense that log messages may typically be distinct newline-terminated lines of text... \$\endgroup\$ – Chris Stratton Nov 8 '19 at 21:41
The CPU will still send data. It doesn't know there isn't a cable.
The CPU makes the voltage go up and down on the pin, and then... nothing happens, because there is no cable. The CPU doesn't know that nothing is happening when it makes the voltage go up and down.
    \$\begingroup\$ Unless of course there is hardware flow control involved. \$\endgroup\$ – jcaron Nov 8 '19 at 22:52
