I'm using MATLAB to analyze an amplifier in a transimpedance circuit, and I'm a little lost in implementing the op amp's open-loop gain function with the following formula:
$$A(s) = A_{OL} \cdot \frac{\omega_0}{s+\omega_0}$$ $$A_{OL} = \text{DC Open Loop Gain, a Constant}$$ $$\omega_0 = \text{Corner Frequency, -3dB from }A_{OL} $$
Using parameters from the OPA656 by TI as a model, I've used the Gain Bandwidth Product (GBW) and the DC Gain to find the corner frequency.
$$GBW = 230 \text{ MHz and }A_{OL} = 65 \text{ dB}$$ $$\omega_0 = \frac{GBW}{10^{\frac{A_{OL}-3}{20}}}$$
What I'm confused about is how the given -3 dB bandwidth and the unity-gain bandwidth factor into the equation. Using the equations, I found that the corner frequency is at 182.695 kHz, and that appears to match up with the values shown in Figure 14 of the datasheet. The datasheet gives a value of 500 MHz for both of them, but the figure in the datasheet seems to extend beyond past that. How can I incorporate the given -3 dB bandwidth and the unity-gain frequency into my equation, or is it not necessary for the model shown here?
