I have seen many manufactures using diodes N<1 for their PSpice model and LTSpice model diodes so I tried to run temperature sweep in LTSpice and PSpice
  • In LTSpice if N<1 DC sweep eg:1m with .temp it dont provide necessary plot Temperature Sweep
For Pspice
Schematic
.MODEL DB D(N=1m)
with Temperature other than 27C we get error
Error
  • So I tried to keep N=1036 and tried to match IS accordingly in EXCEL but the overlayed result diode current dont match for N=1m enter image description here
  • Is there any other way to match diode drop and current in PSpice of N=1m, So that it can be temperature swept?
  • \$\begingroup\$ N is usually 1...2,3 or so, and Is ranges from femto to micro, or nano, so what you have there may be an abomination. It might be time to step back a bit and rethink. \$\endgroup\$ Nov 11, 2019 at 20:10
Regarding LTspice, you cannot simultaneously use a .TEMP and a .STEP command .
.TEMP is an archaic form of the step command for temperature. It is equivalent to
.STEP TEMP LIST <T1> <T2> ...
which reveals why adding another .STEP command yields no simulation.
Just use e.g. a transient analysis, like
.tran 1m
.step temp list 0 20 40 60 80 100
OR
.temp 0 20 40 60 80 100
to step the temperature.
  • \$\begingroup\$ Thanks for mentioning it but is it possible to match N=1m (in PSpice) behavior by above methods which I mentioned i have to carry it out by 1] Spice diode statement [2] Macro--Model Sub circuit ?(*As I mentioned N=1m notifies overflow of the device) \$\endgroup\$
    – Pai
    Nov 11, 2019 at 12:07
