I am unable to find the maximum current this fuel gauge IC can pass from its datasheet.
Can anyone tell me?
The datasheet doesn't say because the maximum current would depend on which FETs you use with it.
The datasheet tells you the capacity range (100mA to 29Ah) but it doesn't say anything about the current.
| improve this answer | |
  • \$\begingroup\$ ,thanks for your response sir,but in datasheet,not specific FET is mentioned. \$\endgroup\$ – Mohan Khedkar Nov 10 '19 at 7:57
    \$\begingroup\$ The maximum current depends on which FET you decide to use in your circuit. \$\endgroup\$ – JRE Nov 10 '19 at 10:47
  • \$\begingroup\$ ok,thank you sir \$\endgroup\$ – Mohan Khedkar Nov 10 '19 at 16:10
