I'm very new to Verilog and I've tried to create single-cycle 32bit MIPS processor.
Instructions I want to implement are
add, and, addi, addu.qb, addu_s.qb, beq, jal, jr, lw, or, slt, sub, sw
but I slightly changed the encoding in instruction jr
( opcode = 6'b000111 ).
The processor should look like this:
I've created that structure in Verilog and also translated a little program to hexa instructions which I want to run in this processor, so I can say if the processor works correctly or not. The problem is when I want to simulate processor in gtkwave and basically debug it, almost all of my "variables" shows their values as "xxxxxx" (picture below) and I don't know why. I would appreciate a little help. I've tried also Google but unfortunately didn't help.
Also below you can find my code describing cpu, instruction and data memory and testbench. Components I'm using in cpu description are correct, only problem is with the simulation.
Thank you for your advice.
module cpu ( input clk, reset, output [31:0] PC, address_to_mem, data_to_mem, input [31:0] instruction, data_from_mem, output WE )
wire Zero, c32, c32_1, c0, c0_1, PCSrcBeq_true, PCSrcJal, PCSrcJr, RegWrite, MemToReg, MemWrite, ALUSrc, RegDst, Branch;
wire [3:0] ALUControl;
wire [4:0] shamt;
wire [5:0] opCode, funct;
wire [15:0] in;
wire [31:0] SignImm, SrcB, ALUOut, ResultMult, PCPlus4, PCBranch, DataIn,four, Rt, Rd, mux_regf_result, thirty_one, res, rd1, rd2, WD3, Result, PCJal, WriteReg;
reg [31:0] PC_reset;
always @(posedge reset )
begin
if ( reset )
PC_reset <= 0;
end
assign PC = PC_reset;
assign thirty_one = 31;
assign four = 4;
mux_4_1 mux_instmem ( rd1, Result, PCBranch, PCPlus4, PCSrcJr, PCSrcJal, PCSrcBeq_true, DataIn );
register_32_bit PC_reg ( DataIn, clk, PC );
adder_32bit adder_PC ( PC, four, c0_1, PCPlus4, c32_1 );
register_file reg_file ( instruction[25:21], instruction[20:16], res[4:0], RegWrite, clk, WD3, rd1, rd2 );
assign data_to_mem = rd2;
controlUnit control_unit ( instruction[31:26], instruction[5:0], instruction[10:6], RegWrite, RegDst, ALUSrc, Branch, MemWrite, MemToReg, PCSrcJal, PCSrcJr, ALUControl );
assign WE = MemWrite;
mux_2_1 mux_left_up_regf ( WriteReg, thirty_one, PCSrcJal, res );
mux_2_1 mux_left_down_regf ( Result, PCPlus4, PCSrcJal, WD3 );
assign Rt = instruction[20:16];
assign Rd = instruction[15:11];
multiplexor_2_1 mux_regf ( Rt, Rd, RegDst, WriteReg );
ext_to_32bit sign_ext ( instruction[15:0], SignImm );
multiplier mult_by4 ( SignImm, ResultMult );
adder_32bit adder ( ResultMult, PCPlus4, c0, PCBranch, c32 );
multiplexor_2_1 mux_alu ( rd2, SignImm, ALUSrc, SrcB );
alu_32bit alu_right ( rd1, SrcB, ALUControl, Zero, ALUOut );
assign address_to_mem = ALUOut;
mux_2_1 mux_datamem ( ALUOut, data_from_mem, MemToReg, Result );
assign PCJal[31:28] = PCPlus4[31:28];
assign PCJal[27:2] = instruction[25:0];
assign PCJal[1:0] = 0;
assign PCSrcBeq_true = Zero & Branch;
endmodule
data memory
module datamemory ( input clk, we, input [31:0] address, wd, output [31:0] rd );
reg [31:0] mem[63:0];
initial begin
$readmemh("./memfile_data.hex",mem,0,63);
end
assign rd=mem[address[31:2]]; //word aligned
always @(posedge clk)
if (we)
mem[address[31:2]]<=wd;
endmodule
instruction memory
module instructionmemory(input [5:0] address, output[31:0] rd);
initial begin
$readmemh("./memfile_text.hex",mem,0,63);
end
assign rd=mem[address]; //word aligned
endmodule
top
module top_module(input clk, reset, output[31:0] data_to_mem, address_to_mem, output write_enable);
wire [31:0] pc, instruction, data_from_mem;
instructionmemory imemory(pc[7:2], instruction);
datamemory dmemory(clk, write_enable, address_to_mem, data_to_mem, data_from_mem);
cpu mipsCPU (clk, reset, pc, instruction, write_enable, address_to_mem, data_to_mem, data_from_mem );
endmodule
testbench
module testbench();
reg clk, reset;
wire[31:0] data_to_mem, address_to_mem;
wire memwrite;
top_module simulation(clk, reset, data_to_mem, address_to_mem, memwrite);
initial begin
$dumpfile("sim");
$dumpvars;
reset<=1; #2; reset<=0;
#80 $finish;
end
always begin
clk<=1; #1; clk<=0; #1;
end
endmodule
EDIT: register code
module register_32_bit(input [31:0] datain,
input clk, reset,
output reg [31:0] dataout);
always @ ( posedge clk or posedge reset )
begin
if ( reset )
dataout <= 0;
else
dataout <= datain;
end
endmodule
reg_file code
module register_file( input[4:0] a1, a2, a3,
input we3, clk, reset,
input[31:0] wd3,
output reg [31:0] rd1, rd2 );
reg [31:0] reg_file[31:0];
always@ ( posedge clk or posedge reset )
if ( reset ) begin
reg_file[0] <= 0;
reg_file[31] <= 0;
end
else begin
if ( we3 )
if ( a3 != 0 )
reg_file[a3] <= wd3;
else
reg_file[a3] <= 0; //register $0 has always to be 0
end
always @ ( a1 or a2 )
begin
if ( a1 == 0 )
rd1 <= 0;
else if ( a2 == 0 )
rd2 <= 0;
else if ( a1 != 0 )
rd1 <= reg_file[a1];
else if ( a2 != 0 )
rd2 <= reg_file[a2];
end
endmodule
