42
I've read that WiFi b/g/n is using 2.3995 to 2.4845 GHz.
Bluetooth is in between: 2.4000 to 2.4835 GHz.
So what will happen when I put a Bluetooth sending device next to a WiFi sending device?
Will the two devices be aware of each other (like two WiFi devices do)?
Or will they send their data as if they were alone (means interference)?
47
Yes, WiFi and Bluetooth can disturb each other.
But both are equipped to handle that. A standard that is not capable to handle disturbance and/or interference will simply be unusable under many circumstances.
The 2.5 GHz ISM band is also used by Microwave ovens and other wireless standards like Zigbee.
Wifi transceivers are able to detect when certain data has been lost and can ask for a re transmission. It is also possible to lower the datarate which makes the link more "robust" in the sense that it is less sensitive to disturbances.
Bluetooth uses frequency hopping, it changes channel (frequency) 1600 times per second. That way if one channel is disturbed only part of the data is lost. Also a re-transmit of data is possible.
So yes, interference happens, it is a fact that the standards simply have to deal with.
  • 14
    \$\begingroup\$ So Bluetooth and WiFi don't have a common CA/CD (collision avoidance/collision detection) system. They simply don't know each other and it's just noise for the other party. That's what I wanted to know. Is that right? \$\endgroup\$
    – zomega
    Commented Nov 11, 2019 at 15:31
    \$\begingroup\$ When I do large wifi transfers from my laptop TO an external device, suddenly my mouse becomes jerky. I think that when the laptop is transmitting a lot, it disturbs significantly the mouse. The same thing doesn't happen when receiving. \$\endgroup\$
    – Thomas
    Commented Nov 12, 2019 at 0:05
  • 7
    \$\begingroup\$ @slebetman and wifi uses frequency hopping. No it doesn't, it is not part of the standard. For WiFi a channel is selected and then that is used, see en.wikipedia.org/wiki/IEEE_802.11 The channel is not changed dynamically so there is no "hopping". But feel free to prove me wrong. \$\endgroup\$ Commented Nov 12, 2019 at 7:35
  • 8
    \$\begingroup\$ @Thomas the explanation is simple: when sending a file, your laptop transmits a signal which is strong at your laptop (and then disturbs the mouse) but weaker at your WiFi access point. When receiving, the situation is reversed, the signal is strong at the access point but weaker at your laptop. Such a weak signal does not disturb the mouse. \$\endgroup\$ Commented Nov 12, 2019 at 7:38
  • 4
    \$\begingroup\$ @Bimpelrekkie correct, WiFi doesn't frequency-hop, but in the early days of 802.11b, many people confused DSSS with FHSS and I think that is how this confusion was born. \$\endgroup\$
    – hobbs
    Commented Nov 12, 2019 at 12:08
23
Wifi uses a listen before transmit system. If the channel is busy, it holds off transmitting. Eventually it gets through. Each channel is fixed. If it tries to use a channel that is busy, from bluetooth, then it will wait. This may reduce the data speed for wifi if it has to wait too much.
Bluetooth for over a decade now uses adaptive frequency hopping (Bluetooth 1.2) so it will actively check each of it's channels to see if they are good or bad, and blacklists them for a while. This is on top of it's normal frequency hopping. If it tries to use a channel(s) that is busy, from say wifi, then it will move on to the next and won't use those wifi channels, essentially not interfering.
So both try to actively prevent interfering with others and suffer data loss or speed loss for it. But because of these techniques, they can coexist. In a quiet environment, the wifi and the bluetooth networks won't even bother each other. In a noisy environment, there goes your bandwidth.
Here is a nice if old (2006!) writeup on interference techniques for wifi and bluetooth (and ZigBee and wireless usb) https://www.eetimes.com/document.asp?doc_id=1273359#
And even newer (but still old) the development of all in one wireless networking ICs that handle both Wifi and bluetooth for the same device, allow interoperability by communicating to each other so that they know when the other is transmitting and what channel, so they can avoid each other. Teamwork. https://www.marvell.com/wireless/assets/Marvell-WiFi-Bluetooth-Coexistence.pdf
  • \$\begingroup\$ What do you mean by "This is onto of its normal frequency hopping."? \$\endgroup\$ Commented Nov 12, 2019 at 11:18
    \$\begingroup\$ I think he means "on top". Bluetooth has a fixed hopping sequence even without interference. \$\endgroup\$
    – patstew
    Commented Nov 12, 2019 at 16:07
  • \$\begingroup\$ @patstew correct. Damn apple autocorrect. \$\endgroup\$
    – Passerby
    Commented Nov 12, 2019 at 22:36
  • \$\begingroup\$ I just posted to askubuntu askubuntu.com/questions/1448407/… what seems to be an example of this interference happening. The question is there way on linux to adjust any of the frequency ranges so they don't step on each other \$\endgroup\$
    – user603749
    Commented Jan 2, 2023 at 19:53
  • \$\begingroup\$ It would be valuable to know more about the adaptive frequency hopping in Bluetooth 1.2. How long does it take for a Bluetooth channel to be marked dirty? How strong must the interfence be, and what duty cycle is needed, for a channel to become dirty? What is the maximum number of channels that can be marked dirty? \$\endgroup\$ Commented Aug 6, 2023 at 14:24
802.11b/g/n WiFi and Bluetooth devices do interfere with each other, but a single Bluetooth device and Wifi can still be used together in the same area most of the time.
Although interference to WiFi from Bluetooth is severe, Wifi frames are usually so short that most of the frames can be received successfully in between the time that Bluetooth is transmitting. 802.11 will retransmit lost frames 7 times by default, so the packet loss is very low, and only a small reduction in performance occurs.
Since Bluetooth 1.2, Bluetooth has implemented adaptive frequency hopping. Bluetooth devices will avoid transmitting on parts of the 2.4GHz spectrum which are in use. So Bluetooth will avoid transmitting on the same frequency that wifi is using, at least in a close proximity environment where the wifi signal is strong enough to cause enough interference to Bluetooth for the AFH to detect it. If AFH is using the packet error rate implementation, it won't detect any busy portions of the 2.4GHz spectrum if the Bluetooth devices are close enough together that they aren't affected by interference. This is often the case, so AFH does not avoid Wifi in this situation.
When the distance of a Wifi link increases, the bitrate is reduced, and the duration of the Wifi frame is increased proportionally. This significantly increases the chance of the Wifi frame not completing before Bluetooth starts transmitting again. If a wifi link drops down to 6mbps from 48mpbs, the frame loss becomes so high due to Bluetooth interference that wifi can become unusable. Also, using 802.11n 40MHz mode will double the interference caused by Bluetooth.
Bluetooth randomly transmits across the entire 2.4GHz band, so it is not possible to change the Wifi channel to fix this issue.
Bluetooth usually transmits at 2.5mW @1MHz bandwidth, although some long range devices can go as high as 100mW. Wifi is typically 100mW @20MHz bandwidth. It may seem like Wifi is much more powerful than Bluetooth so interference from Bluetooth would be minimal, but it doesn't work like that due to the nature of the wide band signal. 100mW @20MHz is equivalent to 5mW @1MHz as far as interference is concerned at least in OFDM modes. Bluetooth is 2.5mW, which is close the 5mW @1MHz that wifi uses. Only a narrow slice of 802.11g OFDM frame needs to be interferred with for the entire wifi frame to be lost. Wifi will then drop down to 1Mbps DSSS which should be somewhat more tolerant of narrow band interference, but the Wifi range is still significantly reduced.
Many devices have Bluetooth and Wifi coexistance, which allows the Wifi and Bluetooth devices which are built in to the same device to be aware of when the other is transmitting
Here is a good article about Bluetooth adaptive frequency hopping: https://www.design-reuse.com/articles/5715/adaptive-frequency-hopping-for-reduced-interference-between-bluetooth-and-wireless-lan.html
