I want to use a full-wave bridge rectifier. My circuit needs 2 amps of current and operates at 12volts (12V @ 2A). I found this https://www.tanotis.com/products/vishay-2w01g-e4-51-bridge-rectifier-diode-single-100-v-2-a-through-hole-1-v-4-pins?gclid=CjwKCAiAzanuBRAZEiwA5yf4ujDS2suLmVHQSYIiL1mhfKOS6jPyQ9xhstmW5uRF4465WDaRHoD6bhoCjXsQAvD_BwE and now I doubt whether it can deliver or allow me to pass 12V via it or not. And please correct me if am asking a dumb question. I am a computer science student and I have no much experience with these things. I am on my way to learn things so please correct me if this is a dumb question.
1 Answer
It means that a voltage drop on the rectifier is 1V when delivering 2A. So the output voltage is input voltage subtracted by voltage drop.
\$\begingroup\$ Okay, It means that if pass 12 V then the output voltage would be 11V right ? \$\endgroup\$ Commented Nov 12, 2019 at 11:20
2\$\begingroup\$ If you pass DC, then yes. But since you use a bridge rectifier, I suppose the voltage is AC, then the answer is no. It will be somewhere 16V. \$\endgroup\$ Commented Nov 12, 2019 at 11:25
\$\begingroup\$ yes, I am passing DC current for Reverse polarity Protection to my circuit. Thank you so much for the answer. \$\endgroup\$ Commented Nov 12, 2019 at 11:28
