I've made a circuit on Logisim that allows me to switch between three LEDs at the push of a button. Essentially allowing me to cycle between OFF, LED1, LED2 and LED3 repeatedly. I'm doing this using four D Flip-Flops.
However, I'm getting an issue that if you hold down the button it will keep cycling through all the options. This isn't much of a problem at low clock speeds but at like 64hz it's unusable. I want to use a higher frequency clock so essentially I want it to only switch when the user presses but if he holds down the switch it won't go to the next iteration in the cycle.
I'm a software developer and can barely remember the stuff I learned in college about circuits so please explain me like I'm 5.
P
EDIT
Thank you guys so much for all the help. I ended up trying to make both the version with 4 flip flops and the one with 3. Both are really good solutions and require about the same amount of circuitry.
4 Flops
3 Flops
  • \$\begingroup\$ If you just want to switch between 4 states. Then why do you need a high clock frequency?? \$\endgroup\$
    – User
    Nov 12, 2019 at 15:31
    \$\begingroup\$ why not just have the (properly debounced) button be the clock? \$\endgroup\$
    – Hearth
    Nov 12, 2019 at 15:32
  • \$\begingroup\$ Well the problem is at like 1-2hz I will probably have to hold the button down for like half second to switch. But if I hold it too long then I will go to the next level and then I have to cycle all the way back around. So it's not really nice UX for the user. It's simple if it just disregarded thee long presses. \$\endgroup\$ Nov 12, 2019 at 15:33
  • \$\begingroup\$ @Hearth what do you mean by that? sorry I'm a noob \$\endgroup\$ Nov 12, 2019 at 15:38
  • \$\begingroup\$ think about this ... how would you do it in software? \$\endgroup\$
    – jsotola
    Nov 12, 2019 at 18:09
I think you should build a proper state machine. I think you will need 8 states, so 3 flip-flops would be enough. The additional 4 states would be used to detect the press of a button, so you would only change which LED is illuminated when the current state of the button is pressed and the previous state of the button was not pressed.
  • \$\begingroup\$ Oh cool thank you this makes sense \$\endgroup\$ Nov 12, 2019 at 15:40
  • \$\begingroup\$ Wont a 3 bit ring counter do the trick? \$\endgroup\$
    – User
    Nov 12, 2019 at 15:58
  • \$\begingroup\$ @ASWINVENU Won't an Arduino do the trick? \$\endgroup\$ Nov 12, 2019 at 16:08
  • \$\begingroup\$ @HarrySvensson Of course. But look at the question. The man want to achieve this using a logic circuit. \$\endgroup\$
    – User
    Nov 12, 2019 at 16:12
    \$\begingroup\$ I AM ACTUALLY A BEAR. ROAR \$\endgroup\$ Nov 12, 2019 at 18:51
May I suggest you create a ring counter. That would be the easiest way to do so.
4-bit ring counter
Here is a link to the info: Electronics Tutorials - Ring Counters
  • \$\begingroup\$ I will try this thanks :) \$\endgroup\$ Nov 12, 2019 at 15:38
    \$\begingroup\$ @AntersBear CLK is your switch. \$\endgroup\$ Nov 12, 2019 at 18:26
