Does a 1S4P 18650 battery need balancing? I read a lot about balancing around the internet. To me it seems like this only applies to the cells connected in series. An all parallel setup would not need balancing. Is this correct?
\$\begingroup\$ How would you ensure that charge current was evenly distributed between parallel batteries? \$\endgroup\$– Andy akaNov 12, 2019 at 16:24
\$\begingroup\$ I have no idea. Just began to learn about electronics. \$\endgroup\$– ForiventoNov 12, 2019 at 16:27
1 Answer
No. In parallel they are electrically a single cell. You can't 'balance' a single cell.
However before connecting the cells together you should make sure that they all have close to the same voltage. If they are new then they should do, but if they are used then you may need to 'balance' them before making the pack.
Don't make a pack from cells of different capacity, type, age, or condition, as they will not share the load equally.
\$\begingroup\$ Thank you. So, this is okay: external-content.duckduckgo.com/iu/… (1 TP4056 for 2 18650, directly connected)? \$\endgroup\$ Nov 12, 2019 at 18:37
