Okay, this may be a stupid question, but at the beginning of my Applied Electronics course they taught us that the differential gain \$A_d\$ of an operational amplifier is ideally infinite; however, in real op amps, we get a limited bandwidth. Which is fine, because it's still very high. My problem raises when I was introduced to common-mode gain and differential-mode gains. In particular, I read that an amplifier subject to common-mode input signals has as a (non-ideal) output a linear combination of its differential mode input voltage mode and its common mode input voltage, i.e., $$A_dv_d + A_{cm}v_{cm}.$$ And for now, everything's fine. But let's consider the practical example in the picture below:
According to what I read, in the schematic above $$V_u=(1+\frac{R_1}{R_2})(v_+-v_-)=\frac{R_1+R_2}{R_2}V_1-\frac{R_1}{R_2}V_2.$$ And since \$\frac{V_1+\frac{R_1}{R_1+R_2}V_2}{2}=v_{cm}\$ and \$v_d=v_+-v_-\$, then \$V_1=v_{cm}+\frac{v_d}{2}\$ and \$V_2=v_{cm}-\frac{v_d}{2}\$. Moreover: $$V_u=\frac{R_1+R_2}{R_2}(v_{cm}+\frac{v_d}{2})-\frac{R_1}{R_2}(v_{cm}-\frac{v_d}{2})=v_{cm}(\frac{R_1+R_2}{R_2}-\frac{R_1}{R_2})+v_d(\frac{R_1+R_2}{2R_2}+\frac{R_1}{2R_2})=\Big(\frac{1}{2}+\frac{R_1}{R_2}\Big)v_d+v_{cm}=A_dv_d+A_{cm}v_{cm}.$$ How are we even just able to say that \$A_d=\frac{1}{2}+\frac{R_1}{R_2}\$? It's limited, fine, but I would've imagined bigger numbers. I guess I can live with a common gain of 1, but since they called both differential gains \$A_d\$, are they seriously the same?
Already from the beginning, I couldn't even understand why would we use $$V_u=(1+\frac{R_1}{R_2})v_d,$$since \$V_u=A_dv_d\$, with \$A_d\$ a big value and, instead, considering an ideal op-amp, as \$A_d\$ approaches infinity, \$V_u=\frac{1}{\beta}v_+=(1+\frac{R_1}{R_2})v_+.\$ But shouldn't \$(1+\frac{R_1}{R_2})\$ be the gain from the non inverting terminal to the output (i.e., closed loop gain), not of the op-amp, or am I wrong? What am I missing? Thank you in advance!
Edit: I am starting to assume that the answer is due to the principle of superposition of effect, i.e., shutting \$V_2\$ off and compute \$Vu\$ due to \$V_1\$, and then shut \$V_1\$ off and compute the overall gain due to \$V_2\$, and adding then the two results together. This could make sense, I suppose, but I can't still figure out why the result is equivalent to \$v_d\frac{R_1+R_2}{R_2}\$, since \$v_d\$ is supposed to be very small and it should therefore be amplified by a high gain \$A_d\$.
Edit 2: fixed typo that made the result wrong, but the question still holds.
Edit 3: fixed the value of \$\beta\$ in the formulas for this schematic. Unfortunately, I chose an unconventional position for \$R_1\$ and \$R_2\$ in the schematic.
    \$\begingroup\$ have you read about the "virtual ground" method of thinking about typical opamp circuits? \$\endgroup\$ Nov 14, 2019 at 1:54
  • \$\begingroup\$ Open loop gain is infinite (ideally), closed loop gain is not so. With extremely large gain, op would be + or - Vsat even with small noise.. using feedback, you can control gain. \$\endgroup\$
    – Deep
    Nov 14, 2019 at 3:33
    \$\begingroup\$ \$V_u=(1+\frac{R_2}{R_1})(v_+-v_-)\$ - This relation is wrong because \$(v_+-v_-)\$ is zero here because of the -ve feedback .... \$\endgroup\$ Nov 14, 2019 at 19:12
    \$\begingroup\$ You are confusing two issues. There is the differential gain of the op amp. This is a very high number, infinite in the ideal. This is the ONLY gain an op amp has. Then, there are differential gains and common mode gains for op amp circuits -- i.e., amplifiers constructed out of op amps. \$\endgroup\$ Nov 15, 2019 at 15:30
    \$\begingroup\$ I have not seen in ANY books, the very first relationship you have written on Vu. You just misinterpreted it. It's simply wrong assumption you started with. \$\endgroup\$ Nov 16, 2019 at 10:20
$$\bbox[4px,border:1px solid red]{V_u=(1+\frac{R_2}{R_1})(v_+-v_-)}$$ The above assumption where you start from is actually wrong.
\$(v_+-v_-)\$ is infinitesimaly small or zero ideally.
The correct relation is: $$V_u = a_d.v_d + a_c.v_c$$ $$ie.,V_u = a_d.(v_+-v_-) + a_c.\frac{(v_+ +v_-)}{2}$$ $$\bbox[8px,border:1px solid black]{V_u = G_{OL}.(v_+-v_-)} $$ Where \$a_d\$ or \$G_{OL}\$ is the open-loop differential gain or simply open-loop gain, and it is very big or infinite for ideal op amp. And open-loop common-mode gain \$a_c = 0\$.
Coming to closed-loop gains in your circuit:
$$V_u=(\frac{R_1+R_2}{R_1})V_1-(\frac{R_2}{R_1})V_2 \tag1$$
The circuit has a negative feedback and you can calculate closed-loop differential and common-mode gains using the relations: $$V_1 = V_c+\frac{V_d}{2}$$ $$V_2 = V_c - \frac{V_d}{2}$$ where \$V_d\$ and \$V_c\$ are differential and common-mode components of \$V_1\$ and\$V_2\$:
$$V_d =V_1-V_2 $$ $$V_c = (V_1+V_2)/2 $$
Equation (1) can be simplified as: $$V_u=(\frac{R_1+R_2}{R_1}).(V_c+\frac{V_d}{2})-(\frac{R_2}{R_1}).(V_c - \frac{V_d}{2})$$ $$\implies V_u = (\frac{1}{2}+\frac{R_2}{R_1}).V_d+1.V_c \tag2$$ Compare (2) with: $$V_u = A_d.V_d+A_c.V_c$$ $$\bbox[8px,border:1px solid black]{\therefore A_d = (\frac{1}{2}+\frac{R_2}{R_1}), A_c = 1 }$$ where \$A_d\$ and \$A_c\$ are closed-loop differential and common-mode gains respectively.
  • \$\begingroup\$ Thank you! I actually made a typo for the result, 'cos I forgot to write a - for \$\frac{v_d}{2}\$. However, I still wonder: when you write \$V_u=(\frac{R_1+R_2}{R_1})V_1-(\frac{R_2}{R_1})V_2\$, since \$V_1=v_+\$ (isn't it? Maybe that's where I'm getting confused) and \$v_-=V_2\frac{R_1}{R_1+R_2}\$ (?), isn't the expression equal to \$V_u=(\frac{R_1+R_2}{R_1})(v_+-v_-)\$? For sure, I got the definition of \$V_d\$ and \$V_{c}\$ wrong, as I defined them for \$v_+\$ and \$v_-\$ instead of \$V_1\$ and \$V_2\$, but I still don't get why the expression I wrote is wrong. \$\endgroup\$ Nov 16, 2019 at 22:10
    \$\begingroup\$ V1 is equal to v+.. But your relationship between v- and V2 is simply wrong ....we know v- is equal to v+....Or in other words you are claiming that V1 is equal to V2. R1/(R1+R2)... . Which is not at all true...... \$\endgroup\$ Nov 16, 2019 at 23:22
  • \$\begingroup\$ Hmm you're right, it makes sense now. \$v_-\$ can't be that value. However, this gets me to another doubt: if \$v_-=v_+=V_1\$, then due to feedback \$v_-=\beta V_u=\frac{R_2}{R_1+R_2}V_u=\frac{R_2}{R_1+R_2}\Big[V_1\Big(1+\frac{R_1}{R_2}\Big)-V_2\frac{R_1}{R_2}\Big]=V_1-V_2\frac{R_1}{R_1+R_2}\$. But if \$v_-=v_+=V_1\$, then \$V_1-V_2\frac{R_1}{R_1+R_2}=V_1\implies V_2\frac{R_1}{R_1+R_2}=0\$, which means that either \$V_2\$ is 0 or \$R_1=0\$. But how is that possible, since it's not general? There must be something I'm missing in the computations. \$\endgroup\$ Nov 17, 2019 at 1:33
