What happen to the voltage level when a solar module is shaded and one of its bypass diode is activated? Assuming this solar module has 3 bypass diodes.
I have been reading and can't seem to understand the theory. Should one bypass diode activate, I will assume the voltage should be 2/3 of the maximum Voc of a solar module?
Thank you.
| improve this question | | | | |
Yes. If a group of cells can't keep its bypass diode reverse-biased, then by definition, the voltage across that group will be the \$V_f\$ (forward voltage drop) of the bypass diode.
| improve this answer | | | | |
  • \$\begingroup\$ Thanks Dave. Wish to clarify what is \$V_f\$ suppose to stand for? \$\endgroup\$ – SunnyBoiz Nov 16 '19 at 9:03
  • \$\begingroup\$ It's the forward voltage drop of the bypass diode, since if it isn't reverse-biased any longer, it must be conducting current in the forward direction. \$\endgroup\$ – Dave Tweed Nov 16 '19 at 12:51
  • \$\begingroup\$ Cool! Thanks for the clarification! :) \$\endgroup\$ – SunnyBoiz Nov 17 '19 at 3:42
