When I physically build this circuit the output voltage doesn't response to load variation.
The voltage across the sense resistor is definitely increasing when decrease the load resistance, the voltage difference between the opamp input pins varies accordingly, and there is a voltage at the output which means the NPN is turning on.
What am I missing?
