The RPi outputs are usually \$3.3\:\text{V}\$ and they probably can handle saturating your PNP as a switch. But the problem is the \$3.3\:\text{V}\$ limit (which assumes zero sourcing current.) The I/O pin can sink current when driven high, but that's not controllable as it is only through a protection diode -- which, in general, you should NOT rely on for these purposes.
If you only have one S8550 BJT (and not two) then you can attempt something like this:
You'll need to adjust \$R_3\$ to get the current you want in the LED. The value I've provided is a wild guess and probably should be larger than I've shown. So perhaps start with a larger value and work towards that one to get the current you want.
You may also need to adjust \$R_1\$. But here's the problem. This circuit relies upon the I/O pin protection diodes and attempts to limit their current to a value that is low enough to avoid latch-up. If you reduce \$R_1\$ in order to increase the base current (when actively driving the LED), then you take risks of too much protection diode current and therefore latch-up. I chose the value you see in order to limit the protection diode current to under \$1\:\text{mA}\$. Some MCUs can handle that. Some cannot. So there's nothing assured about this specific design. It's a risk. But it may be satisfactory, too. Just know that this isn't well-managed and that you may be taking some risks. But the pay-off is that it may work okay.
A final note about the above circuit. There still may be some LED light, even when turned off (I/O pin high.) That's because there's still a small amount of base current. I've tried to keep that base current to around \$1\:\mu\text{A}\$, so there shouldn't be much LED light. But in a dark situation, I can't promise you won't notice it. So, even assuming everything else appears to work out, it's still possible that you may see "some" emission from the LED when you've tried to turn it off.
If you have two S8550's handy, then you can attempt the following:
Here \$Q_2\$ is operating as an emitter-follower and \$R_3\$ is used to regulate the current into the LED. I chose to assume about \$1\:\text{V}\$ across \$R_3\$. Given that, and assuming about \$V_{\text{BE}_1}\approx 800\:\text{mV}\$, this means we want about \$3.2\:\text{V}\$ at the base of \$Q_1\$ (when the LED is on.) There's a problem at this point -- I can't be sure that \$Q_1\$ is saturated. It may not be -- it depends on the LED's required voltage. Just to manage the situation, I decided that I want at least \$3\:\text{mA}\$ in \$R_2\$ (this will guarantee a certain range of emitter currents for \$Q_2\$), so I set \$R_2=\frac{5\:\text{V}-3.2\:\text{V}}{3\:\text{mA}}\approx 560\:\Omega\$. \$Q_2\$ will be saturated by design (\$R_4\$ will guarantee it) and I therefore expect about \$2.5\:\text{V}\$ at the base of \$Q_2\$. If I assume that \$Q_1\$'s base current will be around the same current I just set for \$R_2\$ (this assumes \$\beta_1\ge 20\$), this means I need to be able to sink \$6\:\text{mA}\$ (which the RPi I/O pin can achieve.) So \$R_1=\frac{2.5\:\text{V}}{6\:\text{mA}}\approx 470\:\Omega\$.
When the LED is off, the I/O pin is at \$3.3\:\text{V}\$ and I want the base at \$Q_1\$ to be at least \$4.5\:\text{V}\$, so that it is off, as well. This means the base of \$Q_2\$ will be about \$3.8\:\text{V}\$. So the base current in \$Q_2\$ now will be about \$1\:\text{mA}\$. About all of that current will be sourced by \$R_2\$ and that means only about \$560\:\text{mV}\$ across it. This does strongly suggest that \$Q_1\$ will be off, which is what's desired.
To keep \$Q_2\$ fully saturated in both cases and recognizing that there won't be much collector current for \$Q_2\$ in either situation, it's a good idea to make its collector resistor "large." Taking the LED *off case to heart, I'd want the collector resistor to be at least \$11\times\$ larger than \$R_2\$, but given my uncertainty about the saturation state of \$Q_1\$ that should be at least double it, again. So at least \$22\times\$ larger than \$R_2\$. I chose \$R_4=22\:\text{k}\Omega\$. You might be able to get by with less, but I'd prefer you didn't.
Now you can adjust \$R_3\$ to get the LED current you need. (The value I provided is just a guess and there are a number of factors, such as ambient and operating temperatures, that will influence your actual choice.)
I don't consider either one of these to be particularly good choices. Both may exhibit a very low level of LED current when turned off that may be visible in some circumstances. Both can be adjusted (for example, try \$R_2=470\:\Omega\$ in the 2nd circuit) to help that. But neither circuit is perfect.
It really is better if you pick up a few different types of transistors to help avoid being forced to use the wrong active devices thereby forcing some compromises in your goals.
