I try to understand some basic concepts, but I'm stuck with this question. I have this schematic, with a power supply 9V, a resistor 450ohm and a LED. Assuming the LED consum 16mA, this resistor have an voltage drop of: 7.2V My questions is why this resistor "limit" the voltage with this voltage drop? I learn that resistors limit the current, not the voltage, so my power supply can deliver 1A, only 16ma would reach to the LED, so why I have a LED power by 9-7.2v = 1.8V and 16mA, and not power by 9V and 16mA?
    \$\begingroup\$ Not sure if I understand what the actual question is, but ideally the LED has a always a certain forward voltage drop over it, here 1.8V, and some maximum current it can tolerate before it burns, here 16mA. The same current flows through the resistor and by Ohm's law R=U/I. So the rest of the battery voltage 7.2V has to be over the resistor so you can either select resistor based on current or current based on resistor. LED power is its voltage and current. \$\endgroup\$
    – Justme
    Nov 17, 2019 at 10:31
  • \$\begingroup\$ Squat down, close your eyes, and say "Ohm's Law" slowly. \$\endgroup\$
    – Hot Licks
    Nov 17, 2019 at 23:24
5 Answers 5
7
My answer is simple: the resistor limits the current and diode limits the voltage.
You can consider this network as a simple current source (a voltage source + resistor) loaded by a voltage stabilizer (the diode). This is a relatively good combination. The best combination would be a perfect current source driving a voltage stabilizer. The worst combinations would be a perfect current source driving a current stabilizer and perfect voltage source driving a voltage stabilizer.
It is easy to explain how the linear resistor limits the current. Just apply Ohm's law to the rest of the voltage across the resistor I = (V - VLED)/R.
But it is much harder to explain how the diode limits the voltage across itself. Perhaps for this reason there are no intuitive explanations for this phenomenon. I will try to explain it by using the concept of dynamic resistance.
In the (almost) horizontal part of the IV curve, think of the diode as an ohmic resistor with high and (relatively) constant resistance. So, when you increase the voltage across the overall network, the voltage across diode increases proportionally to the current through it - V = I.R (see the top of the picture below).
A diode as a dynamic resistor
But when you enter the vertical part of the IV curve, supprisingly the diode begins changing its resistance - you increase the current but it decreases its resistance with the same rate. As a result, the product of them - the voltage across diode, stays constant (see the bottom of the picture above).
I have shared this explanation in the RG discussion of How many types of resistance can be represented by a variable resistor?
You can see there a graphical representation of another version of this clever trick where the overall voltage stays constant... the limiting resistor decreases its resistance RL... but the "diode" decreases its static resistance RST as well. As a result, the two IV curves rotate and their intersection (operating) point moves along the new IV curve of the "diode". It is a vertical line in this region; so the voltage drop across the "diode" stays constant.
Non-linear resistor with zero differential resistance
The resistor is not limiting the voltage for the diode, the voltage on a diode can be considered as constant:
Source: Tutorialspoint.com
As you can see in the diagram, the voltage of a diode is kind of "fixed" around the specified forward voltage (around 0.7V for a normal diode, 1.8V for a red LED). If the voltage over the diode is increased further, the current is increasing rapidly. Without a series resistor this is exactly what would happen - the current increases and the diode burns up (if the power supply delivers more current than the diode can handle).
But with a series resistor there is a kind of "negative feedback": If the voltage over the diode would increase, the current would increase a lot. This higher current would create a higher voltage drop in the series resistor (U = I*R). And a higher voltage drop in the resistor means less voltage for the diode. Thus the resistor is effectivly limiting the current through the diode and only by that it is also fixing the voltage.
  • \$\begingroup\$ jusaca, congratulations on the original explanation... but I think you need to rethink the second paragraph... \$\endgroup\$ Nov 17, 2019 at 22:20
  • \$\begingroup\$ A power supply that can not deliver the current, it represents a supply with series resistor, so I think the reference to it is really confusing. (Maybe remove it, as it is not needed to make the point, and the point is good?) \$\endgroup\$ Nov 18, 2019 at 6:01
  • \$\begingroup\$ Every power supply has a maximum output current, what is confusing with that? \$\endgroup\$
    – jusaca
    Nov 18, 2019 at 7:00
  • \$\begingroup\$ We can see something like negative feedback in the way the diode keeps the voltage constant. Think of it as of a dynamic resistor that decreases its resistance when the current increases and v.v. In this way, the diode prevents the current from changing the voltage (see my comment below). \$\endgroup\$ Nov 18, 2019 at 7:15
6
consider this
For normal silicon diodes, between a picoamp and many milliAmps, the current increases 10:1 for every 0.058 volts increase in diode voltage. Thus the current is exponential function of the voltage, and the voltage is a logarithmic function of the current.
Thus there is no threshold voltage.
You have to sacrifice an amount of voltage to activate/open LEDs. That voltage is known as forward voltage Vf. In your case, Vf of the used LED is around 1.8 V, so it sucks 1.8 Volts and after that the LED is almost a short circuit. Remaining 7.2 volts drops on the resistor.
Subtract LED volt drop from supply voltage. Now, connect your resistor to the led and do the math. If LED drop is 1.8v, 7.2V / 450 Ohms is 16.66mA.
