I want to draw a state diagram about the sequence detector circuit. The circuit will generate a logic “1” output is a sequence of 11 or 1001 is received. I have my answer, but I don't know my answer whether correct. Please help me check.
New result here: enter image description here
    \$\begingroup\$ Looks right.... \$\endgroup\$
    – Mitu Raj
    Nov 18, 2019 at 10:07
  • \$\begingroup\$ This would fail to detect the "1001" subsequence of "11001". \$\endgroup\$
    – Hearth
    Nov 18, 2019 at 14:14
  • \$\begingroup\$ How can I change it? \$\endgroup\$
    – JoJo
    Nov 18, 2019 at 14:37
  • \$\begingroup\$ how about my new state diagram? Is that correct? \$\endgroup\$
    – JoJo
    Nov 18, 2019 at 15:19
  • \$\begingroup\$ Do you need to write this as a state machine? Because you describe a 4 bit shift register with 2 comparators. \$\endgroup\$
    – DonFusili
    Nov 18, 2019 at 15:20
Your second state machine is correct.
10&1001 State Machine
  • \$\begingroup\$ Hi @stainlesssteelrat may i know the tool you used to draw the FSM \$\endgroup\$ Mar 27, 2020 at 5:27
  • \$\begingroup\$ I believe it is DIA. \$\endgroup\$ Mar 27, 2020 at 9:50
