7
I grabbed an LED and then scraped an aluminum plate with a pin, and it turned on at some points, at first I thought it was electrified but it wasn't, then I tried with another aluminum plate and it also happened.
Later I tried the same thing with a cable connected to my computer's microphone jack and recorded the spectrum:
The first image is zoomed in, and the background waves are noise from the mains
What is causing this?
  • 5
    \$\begingroup\$ Well done! Now did you have a question? \$\endgroup\$
    – Oldfart
    Nov 18, 2019 at 14:21
    \$\begingroup\$ This is awesome - love the exploratory nature ! As @Oldfart mentioned, you did not ask a question and only stated what you observed. This 'question' will be closed if there is no question to answer. \$\endgroup\$
    – efox29
    Nov 18, 2019 at 14:23
    \$\begingroup\$ It is likely the triboelectric effect, however I am not certain of this. \$\endgroup\$
    – rdtsc
    Nov 18, 2019 at 15:35
    \$\begingroup\$ @DKNguyen apparently it does for aluminum, but it is only slightly positively-charged. \$\endgroup\$
    – rdtsc
    Nov 18, 2019 at 16:25
    \$\begingroup\$ In the LED experiment i was touching one pin and the other pin was scraping the aluminum, it seems that the led turned on because the effect generated AC and i have some capacitance, in the microphone experiment it was the same but the capacitance was from the sound card \$\endgroup\$ Nov 18, 2019 at 17:15
There are two factors at play here.
The first thing to understand is that all aluminum has a thin clear layer of Aluminum Oxide on it, and when you scrape it away exposing pure aluminum it will very quickly reform, so it is almost always there.
Aluminum Oxide has a significant piezoelectric effect, strong enough that it is often used in science experiments specifically for this effect. So as you are scraping across the top of the metal you are breaking apart the bonds in the Aluminum oxide and as you do this it causes little jolts of voltage. You can even see this effect if you crush a sapphire in a dark room with a hammer, little sparks will form momentarily. A sapphire is just Aluminum Oxide more or less.
The piezoelectric effect I just described is likely the dominate effect.
There is a second effect that would be more than strong enough to show up as well, though I suspect less pronounced, that is what is called the Galvani potential of the two metals. When you have two dissimilar metals and they come in contact for a short time a small current flows and there is a difference in potential between them. In fact, the amount of voltage difference is determined not just by the metals but the temperature. This is exactly how thermocouples work, they are just two wires o different metals touching, we measure the voltage across them and this translates to a temperature.
Since the metal of your probe is not aluminum when it comes in contact with the aluminum a small voltage is produced. As you scrape over the rough surface the connection between your probe and the underlying aluminum isnt making great contact (remember there is a non-conductive oxide layer you are cutting though). On a microscopic level your probe is bouncing up and down making momentary contact with the aluminum as it scratches across very quickly. So this constant scratchiness between the two metals is likely causing the normal potential difference to vary and adding some noise to your plot as well.
    \$\begingroup\$ Well, all aluminum that's been exposed to oxygen has an alumina layer, anyway. Which is most aluminum, but not all! \$\endgroup\$
    – Hearth
    Jun 25, 2021 at 4:02
    \$\begingroup\$ @Hearth very true, and I do hope there was some oxygen in the room with him as he performed this experiment :) \$\endgroup\$ Jun 25, 2021 at 4:03
