I'm designing a rocket launch controller, that incorporates an Arduino to provide a safer and more controlled launch. Original rocket launch controllers used to use an incandescent light bulb and a button that when pressed it would allow enough current to flow through and launch the rocket (see below schematic).
What I'm trying to do is use the Arduino to verify that the circuit is closed and then use a MOSFET to provide the correct voltage and current for the rocket motor starter to launch the rocket. How would I prevent 12V from going into D3 and A1?
  • \$\begingroup\$ " How would I prevent 12v from going into D3 and A1?" is the wrong question and this is the wrong design. You need a valid spec. For reliable pre-launch and safe launch with some consideration of potential EMI risks. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 19 '19 at 8:02
  • \$\begingroup\$ Where is the Arduino ground connected in this circuit? \$\endgroup\$ – Elliot Alderson Nov 19 '19 at 16:27
  • \$\begingroup\$ Tony, what emi risks would there be? \$\endgroup\$ – Austinthemighty Nov 19 '19 at 18:53
  • \$\begingroup\$ @Elliot Alderson Gnd is connected to the Gnd pin on the Arduino, forgot to throw that in. \$\endgroup\$ – Austinthemighty Nov 19 '19 at 18:55
