I am trying to learn the theory of operational amplifiers. I am using books like Millman, Halkias and Boylestead, but I found that these books do not actually tell the following aspects of those devices:
  1. What exactly is an operational amplifier?
  2. What was the idea behind its creation?
  3. What exactly is an opamp composed of? (obviously, it isn't just a triangle which obeys whatsoever equations you write).
What is the simplest answer for those questions?
8
What exactly is an op-amp?
An opamp is a very simple device that does this: Vout = Gain*(Vin+ - Vin-). The Gain is fixed for each opamp and is usually 100,000 or higher. To make matters more interesting, this gain value is not very "tight". The gain of a real opamp might change over some large range depending on temperature, voltage, batch, frequency, etc. I would not be surprised to see this gain change from 100,000 to 1,000,000 in the same opamp.
Most practical opamp circuit require negative feedback to produce other gain values and to make the opamp behave more predictably.
I can't ask the guy who designed it, but simply put an opamp is one of the most flexible semiconductor devices available today. I am guessing that the original inventor knew this and that's why it was invented. So in a sense, this question is a bit like asking "why was the wheel invented". But this is a super generalization.
The op-amp itself is an integrated circuit, a chip. Before chips there were discrete transistors, and before that there were vacuum tubes. There are circuits that are functionally equivalent to opamps that were used back in the tube days. So the chips that we call "opamps" are "just" modern manifestations of those tube circuits.
What is an opamp composed of?
Modern opamps consist of transistors, diodes, resistors, and some other minor stuff. Of course they used to be made of tubes. The following image shows an internal schematic of one opamp:
Of course there are hundreds (or thousands?) of different opamps so there are many different internal schematics. Some of them are much simpler than this one.
I glossed over this before, so I'll restate it here: Most practical opamp circuits require negative feedback to make things work well. Without feedback, an opamp works nicely as a voltage comparator. For almost everything else, negative feedback is required. This feedback is the source of much magic, and the reason why opamps are so useful. Feedback is beyond the scope of this question/answer, but suffice it to say that this is where the important stuff happens.
  • \$\begingroup\$ I doubt whether a human mind can design a complicated circuit like the Opamp you have cited. I sthere any mathematical trick to decide the internal circuit configuration of an opamp, i.e. given the purpose , do we have a tool that provides the required opamp configurations immediately ? \$\endgroup\$
    – Primeczar
    Commented Oct 30, 2012 at 19:13
  • 5
    \$\begingroup\$ @Primeczar - You doubt that someone could have designed the op-amp in David's post? Well, I've got news for you. I personally know people who have designed power-amplifiers far more complicated then that, using only a pencil, paper, and the contents of their head. Welcome to analog engineering. \$\endgroup\$ Commented Oct 30, 2012 at 19:26
    \$\begingroup\$ For that matter, how did people design things before we had computers, then? In the 50s, you could actually buy vacuum-tube based op-amps. A single device was the size of a soda-can, but they were available. \$\endgroup\$ Commented Oct 30, 2012 at 19:28
    \$\begingroup\$ @Primeczar You caught me. It is really alien technology first passed down to the Mayans and then hidden away by the Illuminati until such a time as their plan to take over the world was becoming a reality. On Decemner 21, 2012 they will reveal the worlds first non-operational amplifier and succeed in their evil plan! <insert maniacal laugh here> \$\endgroup\$
    – user3624
    Commented Oct 30, 2012 at 20:06
  • 4
    \$\begingroup\$ @Primeczar, I find it remarkable that (1) you doubt that a human mind can design a modest opamp circuit but (2) seem ready to accept that a human mind can design a tool that "knows" how to design an opamp. \$\endgroup\$ Commented Oct 30, 2012 at 22:15
what exactly is an operational amplifier?
what was the idea behind its creation?
From its name Operational Amplifier, it is much clear that an amplifier which can perform any operation. You can perform many types of work with this. Like for an example.
  1. You can make a voltage comparator with this, it will give output High or Low (Depends upon your design and need) for some certain level of voltages.
  2. You can make a hysteresis output for any input signal.
  3. You can invert any positive signal and or invert any negative signal.
  4. You can calibrate any signal with your required signal level.
  5. You can use it for amplification of your input signal. For an example, those signal who have very very low level changes that may be difficult for you to judge from any Meter. You can use this for amplification of that signal change to your required level which can be monitor or measure through Meter or any Controller.
  6. It can be use with Audio Amplification.
Thus their are so many applications of Operation Amplifier, May be now it is cleared to you
what exactly is an opamp composed of? (obviously, it isn't just a triangle which obeys whatsoever equations you write).
All Integrated Circuits including Microprocessors, Microcontrollers, Operation Amplifiers, FPGAs etc etc are basically composed of Transistors. Very common operational Amplifier LM741 has been made with more than 32 Transistors.
In theory an OP-amp is an ideal differential amplifier with:
  • Infinite open loop gain
  • Infinite input impedance (no input current is drawn)
  • Zero output impedance
These properties make it very easy to reason about its behaviour. Real OP-amps don't have infinite gain or infinite input impedance but the actual figures are high enough that the assumptions above still hold as approximations. So it is easy to design and build the standard circuit circuits you have seen in your books: voltage follower, integrator, etc, with usually just the addition of maybe a stabilising capacitor, use of a practical load, etc.
    \$\begingroup\$ They began as a theoretical exercise (what if we had an amplifier with the characteristics above). Eventually they could be built with great difficulty, and today they have been developed to the point that they are inexpensive and plentiful. \$\endgroup\$
    – gbarry
    Commented Oct 31, 2012 at 0:18
