I'm considering using this zero-cross detector circuit in a design but I'm struggling to understand exactly how Q1 is activated. The description says "Q1 turns on and feeds current from C1 to the opto via R4, whenever the mains voltage (divided by (R1+R2)/R3) is lower than the voltage across C1." I understand this, but it doesn't explain how the gate of Q1 is activated. In order for the optocoupler to indicate a zero crossing, the gate must be activated only when a zero-crossing occurs, so its reasonable to assume that it has something to do with the capacitor discharging, but how it actually happens is still eluding me. Can anyone venture an answer?
\$\begingroup\$ those four diodes, D1-D4, kinda look like a full wave rectifier, don't they? \$\endgroup\$ – vicatcu Nov 21 '19 at 1:48
D1-D4 form a bridge rectifier that will charge C1 up to about 1/20th of the peak voltage of the incoming AC power. (R1 + R2 are 440K, R3 is 22k 440/22 = 1/20).
During this time that C1 is charging the current will flow through C1 and through D5. This will reverse bias the base emitter junction of Q1 so it will not pass any current.
For a short period at the the end of each 1/2 cycle of the incoming AC the voltage will will drop to a low value and C1 will start discharging into R3 via the base emitter junction of Q1. (The emitter will be negative with respect to the base). This in turn will cause a pulse of current to flow in the collector of Q1 through the optocoupler LED from C1 (which is still charged at this time).
The pulse of current will cause the output transistor of the opto-coupler to draw current and cause the output voltage to pulse to ground for a short time (500us-1ms).
These pulses will be centred on the zero-crossings of the input signal.
1\$\begingroup\$ These pulses are centered active low 500us before ZCS then high 500 us post ZCS \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 21 '19 at 2:11
1\$\begingroup\$ @TonyStewartSunnyskyguyEE75 - thanks, that was what I was meant. \$\endgroup\$ – Kevin White Nov 21 '19 at 3:26
\$\begingroup\$ yes . and a higher 22k value like 50k reduces the PW so care must be taken if using edge-logic. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 21 '19 at 3:33
\$\begingroup\$ I elaborated on this in my answer below. \$\endgroup\$ – Shadetheartist Nov 21 '19 at 6:51
I am learning electronics myself and Kevin's answer confused me to the point where I was wondering what I was misunderstanding about the circuit, so I simulated it and found that my initial instincts and node analysis were actually correct. I will explain:
The following is my copy of your circuit in LTSpice, ignoring the isolation aspect, which should be straightforward, and is not what the question is about.
My understanding is as follows:
R1
and R2
serve primarily to limit the current from mains (120/240VAC).
C1
is a bypass capacitor that serves to smooth the input to the rest of the circuit.
D1 D2 D3 D4
form a full wave bridge rectifier. This normally functions to rectify an AC voltage source into DC, but in this circuit the values of the resistors and capacitors have been specially selected to perform a different function; zero cross detection.
R3
serves to control the voltage at Vin
, the south end of this resistor can be thought of as ground.
C2
is a carefully chosen capacitor that would normally serve as the smoothing capacitor for the bridge rectifier, but in this circuit it's value in combination with resistor R4
control various properties of the zero crossing 'signal'.
Here is the input signal and Vin
superimposed. Note that when the input signal nears zero Vin
is pulled low. This is the effect of the transistor going into its active region (explained below) and providing a path for the energy stored in the C2
to discharge through R4
Note: I've done some math to superimpose Vin
over the AC input signal so the output is clearer.
So the simulation seems to show the circuit functioning as desired.
How it works is a bit tricky, or at least I think so.
The following is Vin
and Ve
The effect of adding a diode at the cathode of C2
basically subtracts the peak voltage and then adds the diode voltage drop.
Note that Ve
can actually go negative. This is the key to understanding the behavior of this circuit.
The following is a plot of Ve
and the current through D5
When Ve
is going positive it hits a ceiling of 500mv or so. This is because 0.5V is the voltage in which the diode is forward biased and acts as a low resistance path to to ground. The voltage at Ve
will remain at 0.5V because the capacitor is charged.
Because Ve
can go negative in reference to ground and the base of Q1
is ground, Vbe
of Q1
is positive which as we know will put the transistor into its active region and allow current to flow from Vc
and Vb
to Ve
As the AC input nears zero C2
will drain through R3
until the voltage at Ve
reaches -0.7V, and Q1
will become active as now Vbe
is 0.7V. This creates a low impedance path for the remaining energy in C2
and the rest of the low input current to flow through R4
and the optocoupler (in your circuit).
This low resistance path is only available until the voltage at Vin
rises to the point where the capacitor recharges and cuts off the transistor.
Here's a plot of Vin
and the current through R4
1\$\begingroup\$ Couple of notes: The AC source value of Vp needs to be 170V to simulate an actual 120VACrms line voltage. Also R3 could be raised to 470K if you want the leading edge of the LED current pulse to be very close to the actual zero crossing instead of having the pulse centered at the zero crossing. In this case the C2 needs a voltage rating of 16V or more. \$\endgroup\$ – Michael Karas Nov 21 '19 at 11:29
\$\begingroup\$ @MichaelKaras Thanks for the input, i forgot about the line voltage discrepancy. As for R3, i was intending to simulate the circuit in the question, so i retained the 22k value, however i did notice that the pulse can be tighter to the zero crossing point by increasing the value of R3. There are also tweaks to R4 and C2 that can serve to the same effect. \$\endgroup\$ – Shadetheartist Nov 21 '19 at 20:15
Some more notes:
In order to keep power consumption as low as possible (for an application running 24/7), I increased R1 and R2 to 560 kOhms each, and R3 to 33 kOhms. I further increased R4 to 2k2, and for Q1 I used a BC517 Darlington type. As optocoupler, I used a 4N35, as recommended.
This worked quite well, but I also wanted to keep impulses short (for firing a triac, I did not want accept impulse width of 1 ms, which I expected to fire the triac too early). For this purpose, I inserted a 5V1 zener diode in the base line of the transistor, and in order to diminish leakage current through the zener diode (before 5V1 is reached), I added a 100 kOhm resistor between base and emitter of the BC517. This procedure reduced the impulse width to about 200 microseconds.
Then I controlled for the phase of the detected zerocross relative to the actual mains zerocross. I found that the impulse was not centered around the actual zerocross (as expected) but just started with zerocross. This means, the impulse comes with some delay. I suppose that the 1nF capacitor C2 (which was 820pF in my case, because I only had this one at hand) causes delay, which becomes more pronounced with my increased resistors. I did some calculations on this, which I do not paste in here, but they supported the idea that C2 tends to delay the impulse. I was fine with a detector with the detection impulse starting right with the actual zerocross.
I am sorry for not providing a circuit after all these changes, but I do not have the software for that. I wanted to share my experience because it includes (a) saving power, (b) decreasing impulse width, (c) delaying impulse onset.
