I'm working on a DIY project where I'm basically creating/connecting my own vinyl record player arm.
I have one of these shellheads in the picture below. Ideally I wan't to be able to use this, and also use the connector show, without soldering cables directly onto it. Is this a regular type of connector, which I can buy the female part of? If so, what is it called? It looks like a short DIN connector, but the pins are perfectly squared, which DIN isn't.
Thank you!
Often called an SME tonearm headshell connector 4-pin. The mating part is either a replacement SME 3009 or 3012 tonearm or a female SME tonearm 4-pin socket. Here are a few examples of available parts:
http://www.audiosilente.com/spare-parts-for-sme-new-sme-3009-connector-with-gold-plated-pins.html
https://www.ebay.com/itm/New-5pcs-lot-Technics-tonearm-headshell-SME-socket-connector-pure-silver-wire-/123834227569
| improve this answer | |
