I have a 10k rotary potentiometer which turns from 0° to 270°. I wire it to an Arduino with the middle pin (2) connected to an analog input (A0) and the other two pins (1 and 3) connected to 5V and GND.
I know the potentiometer is a voltage divider between pin 1, 2 and 3 as above so as expected I get 5 volts on pin 2 when the potentiometer is turned left (0°), 0 volts when the potentiometer is turned right (270°) and something in between in the middle. The problem comes when I try to calculate the angle - voltage function. I expected that it would be a linear function that can be calculated from the two given points (0°, 5V) and (270°, 0V) but when I turn the potentiometer to 135° which is supposed to be the middle point I don't get 2.5 volts instead I get something around 1.5 volts. I also noticed that when close to 270° a single ° in rotation corresponds to a bigger voltage change than when closer to 0°. So is this normal or is my potentiometer busted? And if it is normal why is it so?
EDIT
I did some measurements and came up with the table below as Umar suggested
Degrees   |  Ohms  |   Delta
   0°     |    3   |     -
   45°    |   480  |    480
   90°    |   972  |    492
  135°    |  1704  |    732
  180°    |  3423  |   1719
  225°    |  7280  |   3857
  270°    | 10300  |   3020
So Kevin White is correct it seems that I have a tapered audio potentiometer and the function is logarithmic (the blue curve in Kevin's answer). Thanks, everybody for your time and effort.
  • \$\begingroup\$ Any current draw at pin 2 will cause a voltage drop through your pot. A voltage follower at pin 2 may reduce or eliminate this effect. \$\endgroup\$ Nov 22, 2019 at 1:03
  • \$\begingroup\$ @Optionparty So what would be the correct way to relate the angle of the pot with the voltage on pin 2? \$\endgroup\$ Nov 22, 2019 at 1:09
  • \$\begingroup\$ Add the datasheet link of the potentiometer. \$\endgroup\$
    – User323693
    Nov 22, 2019 at 1:22
    \$\begingroup\$ It might be a log taper pot \$\endgroup\$ Nov 22, 2019 at 1:24
  • \$\begingroup\$ @Umar, unfortunately, I don't know model or maker so I can not find the datasheet the only thing on it says A10K \$\endgroup\$ Nov 22, 2019 at 1:27
It is almost certainly an audio taper version. They have a pseudo-logarithmic law that works better for audio applications because of the way that we perceive loudness.
The A10K means audio taper potentiometer 10 kilo-ohms. One marked B10K would have a linear law that does what you expect.
Pot laws
The picture was taken from this site Resistor Guide
