I am supposed to get rid of the steady-state error for ramp input for this closed loop transfer function
Transfer Function of Closed Loop ^ T(s)
Closed Loop ^
Since the closed loop is equivilant to the Open Loop below
Open Loop ^
I found out that the G(s) is ^
From as far as i know to get rid of transfer function i have to turn G(s) to a type 2 system(by adding another pole at the origin) since there is no steady-state error for ramp input for type two system so I tried the method (1) below
method 1 ^
But using MatLab I am unable to get the result that I desired which is zero steady-state error for a ramp input (not sure if code error or what)
num=[198025];
den=[1 445 0 198025];
t=0:0.005:10;
r=t;
y=lsim(num,den,r,t);plot(t,r,'-',t,y)
Matlab script ^
But the result I got is something like this
Matlab Result ^
Instead of something like this (note ** that is just some example I found online on how a type two system should be with ramp input)
I found out there are positive poles but i am not quite sure what to replace the 1/s with to ensure that there isnt any positive poles while removing the steady-state error for ramp input as well
and also is there a way to get rid of the steady-state error for ramp input by cascading another function at the end or the back of the Transfer function( Method 2 ) without altering the original circuit (the original closed loop transfer function)?
something like this ^ (which is the way I am supposed to do)
Any help would be wonderful Thx.
