Here is the truth table:
The exercise is to write the SOP of this truth table using a multiplexer with 2 select lines and 4 inputs. I got the SOP expression: $$(\lnot a\lnot b c)+(\lnot a b \lnot c) + (a \lnot b \lnot c) + (abc)$$
I assume that each expression in the parenthesis is one of those 4 inputs.
I understand how a multiplexer works I just don't understand exactly how I am supposed to apply it here. My professor wants us to use a 74151 chip. Here is the datasheet enter image description here
I think I am only supposed to use one of those 2 outputs...
The question is: "Write the SOP expression so as to implement a multiplexer with 4 inputs and 2 selectors. Use the chip 74151 and NOT gates if necessary".
I don't understand the idea behind using a multiplexer here. Can someone explain? Thanks
  • \$\begingroup\$ Do you know what a "lookup table" is? \$\endgroup\$
    – Hearth
    Commented Nov 23, 2019 at 18:09
  • \$\begingroup\$ @Hearth No, what is it? \$\endgroup\$ Commented Nov 23, 2019 at 18:10
  • 4
    \$\begingroup\$ look it up.... ;) \$\endgroup\$ Commented Nov 23, 2019 at 18:39
  • \$\begingroup\$ @SilenceOnTheWire That was a hint for what to look up. \$\endgroup\$
    – Hearth
    Commented Nov 23, 2019 at 18:40
  • \$\begingroup\$ Consider the rows of the truth table in pairs. Something is constant about each pair of rows, and something is not. Consider how you might exploit that. I hope you're prof allows an inverter or two as well as a mux :). \$\endgroup\$
    – vicatcu
    Commented Nov 23, 2019 at 18:52
It is absolutely trivial to implement a 3-input Boolean function using an 8-to-1 mux because, literally, an 8-to-1 mux's function is, given three bits of "select" input, choose one of its eight data inputs. What is a truth table, if not that precise definition, using a mux whose data inputs are degenerately connected to HIGH and LOW values?
Here's a visual that might help, mapping a 2x1 mux schematic symbol to it's truth table.
But like I said, that is trivial. A more interesting question is, can you do the same thing with a smaller 4-to-1 MUX. Start with the truth table, and for a start consider the first two rows:
b2 b1 b0 v
0  0  0  0
0  0  1  1
When b2=0 and b1=0, v = b0... now map that to the behavior of a 4-to-1 multiplexer where b2 and b1 are your select bits. When b2 = 0 and b1 = 0, then multiplexer input 0 = b0. Carry on that reasoning for the subsequent three pairs of rows and you can implement any three input boolean function using a 4-to-1 mux, but you will, as I commented earlier, need access to an inverter and LOW and HIGH in many cases to pull this off.
A clever trick... you can use a similar reasoning to demonstrate for yourself that a 2x1 mux represents a universal gate, similar to NAND and NOR. The proof is left as an exercise to the reader.
