This is the primary mounting connector for Pulsar 2010, 2020 & 2030 Taximeters. I have looked many times and have never seen this exact one...
It is symmetrical with 5 pins. The pins have lip on the outside edge that after they have been crimped cause them to lock to casing.
Hopefully the pictures are clear enough.
Thanks.
Ok, here is a scale as requested.
mm scale
Back area
Front angle on mounting bracket
    \$\begingroup\$ What's the pitch? \$\endgroup\$
    – Tom L.
    Commented Nov 24, 2019 at 18:17
  • \$\begingroup\$ @TomL. Added a scale photo as requested. \$\endgroup\$
    – GB - AE7OO
    Commented Nov 24, 2019 at 19:53
  • \$\begingroup\$ @TomL. - That pitch looks like it might be almost, but not quite, 8mm - perhaps around 7.6mm which happens to be 0.3 inches? (Thanks for adding the photo, GB - AE7OO) \$\endgroup\$
    – SamGibson
    Commented Nov 24, 2019 at 20:39
  • \$\begingroup\$ @SamGibson I'll add one with inches seeing how that is most likely what it was specified in originally. The 2030s date from 2003, the 2020 from 1997 and I can't remember when the 2010 was release, but much earlier. Ekkk... I can't, I just installed my last harness...Arrgghhh \$\endgroup\$
    – GB - AE7OO
    Commented Nov 24, 2019 at 21:59
This looks like TE part 54489-5 pitch is .312"
Contacts 53892-2 are seperate from the housing.
  • \$\begingroup\$ That's it! Thank you. While it does not mount the same, the contact interaction is compatible.. \$\endgroup\$
    – GB - AE7OO
    Commented Nov 26, 2019 at 22:22
