I understand that the physical sizes of microchips are generally limited by silicon yields. The larger your chip is, the more waste occurs when you hit a defect in the silicon and have to throw it away, and at some point this becomes unsupportable. I've noticed, however, that modern GPUs always seem to be significantly bigger than CPUs.
High-end consumer GPUs seem to run in the 400-600 mm^2 range, with the RTX 2080 Ti sitting at a whopping 775 mm^2.
It's a bit harder to find die sizes for high-end consumer CPUs, but it looks like the i9-9900K, for example, has a die size of 178 mm^2. The latest Ryzen generation has even smaller sizes, what with their "chiplet" architecture, with the largest single die being the I/O die at around 125 mm^2.
Why are GPUs so much larger than CPUs? Is it something to do with silicon yields and chip architecture, or is there some kind of economic consideration?
