What's the downside for each? Is the boom stand more steady, but takes up more desk space? I'm debating between the two, but I can't seen to find any info on the pros/cons of each type.
  • \$\begingroup\$ I've heard people say the baseplate with the sliding boom is more stable. If I got one, I would opt for the clamp with articulating arm though since that's less weight in shipping. It's not like you solder with a very high magnification anyways. \$\endgroup\$ – DKNguyen Nov 26 '19 at 20:25
  • \$\begingroup\$ Both must be clamped to a secure (granite) table if using high mag. on a long reach. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 26 '19 at 20:26
  • \$\begingroup\$ granite? So I just have a pine work bench that I would clamp it to. Are you saying it'll bend the desk due to the weight? \$\endgroup\$ – Oggie Nov 26 '19 at 20:30
    \$\begingroup\$ Unless you're working on large boards, just get the simple biology lab base and throw something over the hole in it. The fancier stands invariably just cause problems - maybe the really fancy ones are okay, but the moderately priced ones are not. In one situation we ended up just chucking the arm into storage, turning the very heavy base that was supposed to hold it around backwards, mounting the focusing rack directly to that and aiming it at the workbench with no base in the way at all. \$\endgroup\$ – Chris Stratton Nov 26 '19 at 20:30
  • \$\begingroup\$ @ChrisStratton That's good to know. Unfortunately, I can never find ones with a wide, thin, biology base with quite the features I want \$\endgroup\$ – DKNguyen Nov 26 '19 at 20:32
