Bought the Max4080 module and as usual I read the datasheet after purchasing it. In the datasheet pin 6 and 7 are NC but on the module those two pins are connected as F1B and F1A:
What F1B and F1A pins is for?
Max4080 SASA means it has gain of 60?
These pins are only used for the MAX4081. They used the same dev board for MAX 4080/4081. If you work with the MAX4080 don't care about these two pins.
Yes, MAX4080 SASA has a gain of 60 in an SO8 package.
